Does CORE One print well ABS?
zapta
(@zapta)
Coming from the Voron world, ABS is my goto filament. The CORE One specification does mention ABS but I don't see it mentioned much here in the forum, as opposed to let's say PETG, PC, and TPU.
Does the CORE One prints ABS well?
Posted : 05/05/2025 10:48 pm
RE: Does CORE One print well ABS?
Don't know about ABS but it prints ASA beautifully.
Posted : 06/05/2025 1:37 am
Barry Robbins
(@barry-robbins)
From the spec sheet......   PLA, PETG, Flex, PVA, PC, PP, CPE, PVB and when using the optional Advanced Filtration System ABS, ASA, HIPS, PA
So, yes ABS is supported.
Posted : 06/05/2025 2:42 am
Biomech
(@biomech)
It have printed ABS without any issue. But I would recommend to switch to ASA. ABS is the filament of the past which has not advantages over ASA. It's just bit harder to print.
Posted : 06/05/2025 9:28 am
Kotaztrafee
(@kotaztrafee)
At what speed is the Core One capable of printing ASA?
Posted : 13/05/2025 3:48 pm
zapta
(@zapta)
Good to know. I will give it a try.
Posted by: @biomech
Posted : 13/05/2025 4:13 pm
Biomech
(@biomech)
Posted by: @kotaztrafee
With 0.6mm HF nozzle the Prusament ASA filament profile has max volumetric speed set to 34 mm^3/s. That's quite fast. Maybe it's possible to print it even faster, but it may not have good layer bonds if you push it too much.
Posted : 13/05/2025 8:35 pm
gb160
(@gb160)
Tried ABS-GF on my Core One yesterday and it printed good, I used the generic ABS profile and adjusted temps slightly.
It takes a few minutes to get going as it heats the chamber. Only a smallish part but very nice result, zero warping.
Posted : 14/05/2025 6:37 am
zapta
(@zapta)
Posted by: @zapta
I got my CORE One, so far am printing ABS only, the results are excellent, and the chamber temperature is higher than that of my Voron.
Will also try ASA though I am happy with ABS.
EDIT: I use the Prusa build plate that is smooth on both sides and first layer adhesion is very good.
This post was modified 10 months ago by zapta
Posted : 27/07/2025 6:25 pm
Print_Fandango
(@print_fandango-2)
I am wanting to print a part for the H2d in my core one and it needs to be printed in ABS.
I have the adv filtration, and I am wondering, how good of a filtration can i expect from it as it will be printing in a not too well ventilated room.
Asking before I contaminate the whole room.
Posted : 02/10/2025 3:42 pm
Posted by: @print_fandango-2
Even with the filtration unit, I wouldn't print ABS or ASA in an enclosed room. The enclosure is not airtight and styrene fumes will leak out. I would move the printer to an open window, or if you can, outside even.
Posted : 02/10/2025 4:53 pm
Artur5
(@artur5)
I've been been printing on a regular basis ASA ( not ABS ) in an enclosed room for several years. The room in question is an office/kitchen where food is cooked not far from my two ( well  enclosed ) printers. I'm still alive (sort of.. )
Some people says that the exposure to fumes from ordinary cooking are  more dangerous than printing ABS/ASA.  So, if I stop posting suddenly, I'm afraid that you'll never know what killed me at last, the fumes from ASA or food ...
Posted : 02/10/2025 5:39 pm
Posted by: @artur5
Have a friend who has smoked for years. Says he's fine.
My printer and dryer is next to a vented window no matter what I'm printing nor drying. Not willing to experiment. I also cook with the fume hood running.
18:26 mark
Posted : 02/10/2025 6:09 pm
zapta
(@zapta)
Since I posted the question here I got a Core One and it prints ABS very well, even better than my Voron 2. I am using the Prusa magnetic sheet with satin surface on both sides.
Posted : 02/10/2025 7:26 pm
