CORE ONE vibrations
Strona 1 / 2
Antimix
(@antimix)
CORE ONE vibrations
Looking at some YouTube videos I have the impression that the CORE One vibrates a lot during printing. 😐
It is true that the tables used some videos were not the best stable support to use... 😆 but however there are difference from the MK4S.
While the MK4S has the print head that prints on the bottom of the printer, the top of the printer vibrates much more because the vibrations are amplified by the height from the table. This is not a problem because the vibrations on the bottom of the printer are less noticeable and because the Nextruder and the plate are at the bottom.
But with CORE One, the COREXY gantry is on the top, and stays always on the top;  when it vibrates during printing the top of the box should be the part that vibrates the most since is the far from the table, and so vibrates the gantry. 🤔
- Can this create issues and vibration artifacts on the print, compared to the MK4S, especially if printing miniatures ?
- Did anyone, that already own the CORE One and a MK4S, experience significant differences in quality on small objects ?
Regards
Opublikowany : 05/03/2025 6:56 pm
No FDM printer is really suitable for printing miniatures; yes, you can do it but you are likely to be disappointed with the quality.  SLA (resin) printers are much better in that role.
Opublikowany : 05/03/2025 7:42 pm
RE: CORE ONE vibrations
It does vibrate more than the Mk4S. I do see some VFAs. Overall quality though is quite good and I'm sure Prusa will dial it in more with firmware upgrades. My XL also vibrates a fair bit but print quality is excellent
Opublikowany : 05/03/2025 9:39 pm
Leehound
(@leehound)
I had the same problem. The core one is very top heavy. My solution was to put it on the floor. I really want to find an affordable table that won’t shake all over the place.
Opublikowany : 06/03/2025 2:58 am
I would recommend placing it on a floor tile.  Many of may printers it on a floor tile or concrete pad with silicone feet.  It helps absorb the vibration and reduce noise.
Opublikowany : 06/03/2025 8:24 am
Artur5
(@artur5)
Part of  the extra vibrations/noise issue is because of the Core One design. This printer, as well as the XL and others like the Voron Trident, features a gantry at the top ( on a fixed XY plane ) and a bed moving along the Z axis. The other Core XY design ( Voron 2.4 ) has a stationary bed at the bottom and a gantry moving up and down along the Z axis,
On the case of the XL Prusa had no choice, because of the interchangeable toolheads, the gantry frame must remain fixed on a XY plane at the top, but with the Core One they were free to choose either way. Both systems have pros and cons but, all considered, I firmly believe that on a single printhead machine, a stationary bed is the way to go.
Opublikowany : 06/03/2025 2:36 pm
Biomech
(@biomech)
I have a sturdy shelf for printers: a 3 cm thick solid wood board supported by three steel brackets, each rated for a 150 kg load, mounted approximately 50 cm apart on a concrete wall. However, the Core One printer vibrates too much at very high speeds. I solved this by placing the Core One on a 40 × 40 × 4 cm concrete tile, which sits on a foam mat on the same shelf. Any noticeable vibrations at high speeds have disappeared.
Opublikowany : 06/03/2025 3:48 pm
1 ludzie polubili
Andytpks
(@andytpks)
It vibrates a lot. I tried with a concrete tile underneath, it doesn't change much. But this happens with particular things, like the classic Benchy at maximum speed.
Maybe "silence mode"...? i'm tired today for more try 😀
Opublikowany : 11/03/2025 5:59 pm
I was wondering what "vibrations" actually means for the Core One. Is it mainly acoustic noise (potentially amplified by the enclosure panels)? Or patterns visible in the prints (VFAs)? Or does the printer visibly shake upon large excursions of the XY mechanism? All of the above? 🤨
Opublikowany : 11/03/2025 6:21 pm
Andytpks
(@andytpks)
For me, just shake of the print. But I think it's quite normal with those speeds and that high center of gravity. Then I have an office table, rigid and beautiful but I recommend a four-legged table 😁
Opublikowany : 12/03/2025 5:49 am
When printing for quality, I almost always slow down my Bambus, MK4S, Minis, and XL.  I can't imagine I would not do the same with the Core One.  Most new users have commented on vibration and noise.  I hope that will improve as they improve the firmware.  If not, I might enclose the enclosure.
Opublikowany : 12/03/2025 8:41 am
Posted by: @andytpks
In a perfect world, that's what input shaping is meant to compensate for...
I would be curious how Prusa did the calibration of the input shaper, and how one does it at home with the optional accelerometer. With the accelerometer mounted to the print head, all it can see -- and hence compensate for via input shaping -- is overshoots and oscillations of the print head. But if the bed also vibrates (relative to the print head), that won't be measured and hence remains uncompensated.
It would be interesting to put two accelerometers on both, the print head and the bed, and use the difference signal from these to calibrate the input shaper, instead of just the print head accelerometer on its own.  I wonder whether there is an improvement in print quality to be gained from this.
(If there were two distinct resonance frequencies, one caused by the head and a different one by the bed, both active during X and Y movement -- can the Klipper firmware even deal with that? Or is it limited to one characteristic resonance frequency per axis?)
Opublikowany : 12/03/2025 11:59 am
FabLabWag
(@fablabwag)
After a good week of testing on a COREone:
The shaking is noticeable but not dramatic. We can see zero influence on print quality so far. We were planning to put the printer in an IKEA 'Bror' but that is a pretty leightweight steel construction (though having thick wooden platforms available) so we are reconsidering.
Opublikowany : 12/03/2025 7:32 pm
Andytpks
(@andytpks)
I added two legs to my table and the situation has improved significantly. The situation is not dramatic, far from it. Simply, in the same place where I had Mk4S and Mk3.5, the vibrations are of a different type
Opublikowany : 13/03/2025 8:48 am
Scotttomo
(@scotttomo)
Following quite a few of the discussions that seem to have a similar thread regarding vibration/noise.
I also notice quite a few people eluding to modification to help with these issues. Is this normal for a new Prusa product and for people to be happy to begin to iron out issues themselves?
Opublikowany : 17/03/2025 11:09 pm
Brian
(@brian-12)
Posted by: @scotttomo
In a nutshell yes.  There always seem to be some issues when a new product is released, but Prusa always gets them fixed.  I'm not aware of a product that they haven't yet.  That's one of the great things about Prusa, they continue to improve the printers years after you buy them.  There's not another manufacturer in this space that does the same.
Opublikowany : 18/03/2025 12:49 am
Rainer
(@rainer-2)
How is input shaping on the bed supposed to work with a Corexy printer?
Which motor do you want to use to compensate for the vibrations?
Of course it works with a bed slinger where the bed moves.
But it can't work with a fixed bed or a bed that only moves in Z.
I strongly recommend that you read the Klipper documentation about the function of Input Shaper.
Opublikowany : 18/03/2025 8:19 am
Posted by: @rainer-2
I think you are mistaken here. If the XY drive (due to its high position in the CoreXY arrangement) shakes the whole frame, it can also induce vibrations in the bed. These vibrations may be phase-shifted vs. the movement of the print head, and may exhibit a different resonance frequency than the print head.
These bed vibrations contribute to the relative displacement between print head and bed being different from what one would expect -- and hence they should ideally be corrected for by shaping the XY drive signals appropriately. Measuring both, the print head and bed movement, via accelerometers would provide the required information.
But I am afraid that the Klipper firmware can only account for (and compensate for) a single resonance frequency for X and another one for Y movements at this time. Hence, if the bed has a different resonance frequency than the print head, one is out of luck.
Opublikowany : 18/03/2025 9:41 am
1 ludzie polubili
NarlyB
(@narlyb-2)
I specifically get very loud resonance vibrations when printing in the X or Y direction of a square.  This happens when printing the perimeters except for the external perimeters.  The printing is otherwise mostly very quiet.  External perimeters do slow down.  I will try slowing down all perimeters to see if this has an effect on the resonance/noise.
Opublikowany : 28/03/2025 10:02 pm
NarlyB
(@narlyb-2)
After slowing all perimeters down to same speed as external perimeters, The resonance/noise simply went away except for a barely perceptible resonance in the Y axis as the print head moves from the front to the back.
Opublikowany : 28/03/2025 11:11 pm
1 ludzie polubili
Strona 1 / 2
