Core One printbed
Just wondering... For those of us like me thinking of the MK4S -> CoreOne upgrade... Will the print bed size change? In other words, will the steel sheets I have work on the CoreOne? Or will we be on the hook to get all new steel print sheets?
Anyone know?
RE: Core One printbed
According to the Blog post and launch video the Steel Sheets from the MK4(S) will work on the Core One.
The Core one bed size is 250x220
The MK4S is 250x210
Obviously the Core One has a height difference too, but that doesn't apply here.
It was said in the promo video that the MK4S>Core One conversion would leave users will a full Core One unit without any sacrifices or compromises, so I would say that although your steel sheet from the MK4s will be useable, as the Core One bed is slightly larger it will most likely come with a larger bed and sheet to accommodate. The bed heating element looks to be the same, although it will most likely attach to a re-designed frame to cater for the different Z axis configuration.
--> MK4 - MK4S - MINI+ - Accelerometer Guide - BambuLab A1 Combo <--
Measure your mk4s heat bed and sheet in Y. You will find there is plenty of room for the extra 10 mm travel. Same with Z lead screws. There is more travel the mk4s cannot use because of the Z bearing. The Core one can use the extra area and Z travel.
