6.3.4 Firmware for Prusa CORE One
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • Smarter heat absorption logic
  • Retuned heatbed PID for thermal stability
  • Automatic display refresh rate fallback
  • Additional updates, improvements, and fixes
This is the stable release of firmware 6.3.4 for the Prusa CORE One, addressing several improvements and bug fixes.
This release focuses on enhancing reliability and fine-tuning the user experience based on recent feedback and internal testing. Users can expect smoother operation, better thermal stability, and quality-of-life improvements across multiple areas of the firmware.
The heat absorption logic has been significantly improved to make your printer smarter — and your workflow faster. The firmware now continuously tracks recent heatbed activity and dynamically adjusts the required stabilization time before printing. If the bed has already been heated, such as when printing multiple objects in succession, switching materials, or using preheat, the usual heat absorption delay is automatically shortened — or even skipped entirely.
This leads to a noticeably faster transition into printing, especially during reprints or tightly timed jobs, helping you save time, stay productive, and get the most out of every print session.
PID values for the CORE One heatbed have been fine-tuned to provide more stable temperature regulation and improved print consistency.
If repeated display anomalies (such as flickering) are detected, the printer now shows a prompt offering to switch to a lower refresh rate. To ensure the dialog remains readable even if the display is unstable, the system temporarily applies the lower refresh rate before displaying the prompt. If the user selects "No," the original (higher) refresh rate is restored.
The display refresh rate can also be adjusted manually at any time in Settings → Hardware → Display Refresh Speed.
Progress reporting during filament auto-retract
The progress bar is now updated during the auto-retract phase of filament load or change, instead of remaining stuck at 99% in the "Loading" phase.
Option to disable grille check warnings
The ventilation grille warning now includes a “Disable” button. The warning can also be managed under Settings → Hardware → Check Ventilation Grilles.
N/A entries removed from print carousel
Print screen carousel now omits entries marked as “N/A” to reduce clutter and improve readability.
Increased retraction after filament change
Retraction during filament unparking has been increased from 2 mm to 4 mm to minimize oozing.
Extended post-print filtration limit
The maximum setting for post-print air filtration has been extended from the previous limit to 90 minutes.
Phase stepping calibration option
A calibration option is now available to fine-tune phase stepping on the CORE One. The feature requires a PRUSA Accelerometer Set and is intended for advanced users who enjoy exploring deeper tuning options and experimenting with motor behavior.
Chamber lights stay on with the camera enabled
When the integrated camera is active, chamber light dimming is now disabled by default to maintain optimal visibility. This behavior can still be manually changed in the settings.
Lights settings
The lighting settings have been reworked to offer more precise control over the printer’s status and chamber illumination.
Chamber dimming behavior can be set to one of three modes:
  • Always – dimming is active even during printing
  • On Idle – dimming only occurs when the printer is not printing
  • Never – dimming is completely disabled, regardless of other settings
Additionally, the chamber light settings have been expanded. You can now fine-tune both the standard and dimmed brightness levels separately, allowing for more flexible lighting behavior during different printer states. The option to toggle the RGB status bar under the heatbed on or off has also been moved into this menu.
Nozzle no longer heats unnecessarily on unload
The nozzle will no longer be heated unnecessarily during filament unload if the filament has already been auto-retracted and only needs to be deretracted for gear clearance.
Nozzle now cools properly after unloading
After filament unload, the nozzle now properly begins the cooldown process.
Corrected door sensor calibration instructions
Corrected the wording in the door sensor calibration wizard. The prompt now properly instructs the user to loosen the tensioning screw, not tighten it.
Release notes:  https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.3.4
Napsal : 18/07/2025 5:26 am
GreenPea
(@greenpea)
... can't see the pictures (links to private-user-github) unfortunately
Loving the learning curve!
Napsal : 18/07/2025 7:31 am
1 lidem se líbí
Ahalm
(@ahalm)
RE: 6.3.4 Firmware for Prusa CORE One
Posted by: @greenpea
Neither do I, but those load fine on the linked release notes.
Napsal : 18/07/2025 5:37 pm
1 lidem se líbí
Michael
(@michael-2)
The printer still homes the print head which seems unnecessary to unload the auto-retracted filament.
I had a situation where the homing failed and  could not remove the  filament . I can’t see why the homing is needed
This post was modified před 10 months 3 times by Michael
Napsal : 19/07/2025 12:24 pm
2 lidem se líbí
wikallen
(@wikallen)
I'd like to see control of the light added to prusa connect.
Napsal : 19/07/2025 5:24 pm
2 lidem se líbí
HKOCH
(@hkoch)
I think there is a bug in this released 6.3.4. Suddenly the chamber fans doesn't turn and it show an error message that they are maybe blocked?
And therefore I now have to open the door printing PETG or the filament gloggs
Only see this if "Advanced filtration" not on "DIY"
This post was modified před 10 months by HKOCH
Trust me, I'm an engineer 🙂 Always do your best. What you plant now, you will harvest later
Napsal : 19/07/2025 8:47 pm
DarthMuffin
(@darthmuffin)
I upgraded to 6.3.4 and now can't load filament and as such the printer is a brick.  I get "Filament Loading Timed Out".  Sometimes immediately, sometimes after doing auto-home.  Tried PETG and PLA.  Filament sensors test fine.  Tried pre-heating the head too.  Anyone else seeing this or have suggestions?
Napsal : 20/07/2025 4:41 am
DarthMuffin
(@darthmuffin)
Update: recalibrating filament sensor fixed it.  I don't know why the sensor tested correctly or why a firmware update would cause this, but it works now.
Napsal : 20/07/2025 4:56 am
1 lidem se líbí
Posted by: @hkoch
Do you actually have the Advanced Filtration option installed on your Core One? (The backpack with the HEPA filter and additional fan.) If not, you should set the Chamber Filtration option in the Settings menu to "None".
On my Core One I don't have that hardware option, and if I select "Advanced Filtration" I get the error message you describe. Which makes sense: The extra fan is not installed, so the xBuddy board will not get any "I'm spinning" signals from it and will assume that the fan is stalled.
If you do have the hardware option, please double-check that it is properly connected and the plug has not come loose.
Napsal : 20/07/2025 10:05 am
1 lidem se líbí
tonyPA
(@tonypa)
The time-remaining is missing on the Absorbing Heat screen. Over-site or intended?
Napsal : 25/07/2025 3:02 pm
1 lidem se líbí
DMartin
(@dmartin)
"Heat absorption" isn't a very English phrase.  I think you mean "Warm up".   I think I understand what "heat absorbtion" means but it's not a commonly used phrase.  "Warm up" is applied to many similar devices, and is more generally understood.   I don't mean to be unduly picky, but this kind of thing puts newbies (and others) off and causes unnecessary head-scratching.
Napsal : 25/08/2025 1:31 pm
REB
 REB
(@reb-3)
Temperature stabilization is probably a more accurate term.
Napsal : 26/08/2025 2:51 pm
3 lidem se líbí
JRPJIM
(@jrpjim)
Display problems Auto Fallback not working.
Blind menu not working Becasue Settings/Right Multiple Turns/ Left 2/ Press/ Right 4/ Press    Should be Right 6 / Press
The original  posted sequence (right 4) results in  Changing  Check Ventilation grills.At least in Core One 6.3.4 firmware
I mite also sugest insted of Press in middle of lower 1/3 screen you Subsitute Rotate right multiple turns /Left One/Press
Took over 4 Hr to get to the Above hope it shortens it for others
Napsal : 10/10/2025 5:51 am
