6.3.3 Firmware for Prusa CORE One
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • Added Ukrainian translation
  • Door sensor now disabled by default
  • Configurable PTFE Tube Length for MMU3
  • Timeout added for ventilation grille prompt
  • Improved G-Code support for chambers (#4479#4484)
  • Fixed BSOD when preheating with "Custom" filament
  • False “Fan Not Spinning” errors on DIY filtration should be resolved (#4593
  • Fixed footer not updating after selection (#4345#4166#4560)
  • Increased max supported nozzle diameter (#4565#4553)
Ukrainian Translation
The printer interface is now available in Ukrainian. Вдалого друку! (Happy printing!)
Door Sensor Disabled by Default
The door sensor emergency stop is now disabled by default on new Core ONE units. You can enable it in the settings.
Note: The sensor must remain connected to the xBuddy board to identify the printer model.
You can now set the PTFE tube length between the extruder and the MMU under Settings → Hardware → MMU.
Ventilation Grille Prompt Timeout
Prompts to open or close the ventilation grilles on Core ONE now automatically dismiss after 60 seconds.
Improved G-Code Chamber Support (#4479#4484)
Chamber temperature is now included in periodic serial reports and M115 capability info. Thanks to @bkerler and our team for the contribution.
Resolved a BSOD caused by long translated strings when preheating “Custom” filament in some languages.
False “Fan Not Spinning” errors on DIY filtration should be resolved (#4593)
Added signal filtering to reduce false fan errors on DIY filtration setups using MK4 fans with longer cables. This should resolve tachometer signal issues.
Fixed a bug where the footer didn’t update correctly after selecting “none.” Thanks to @bkerler for the fix!
Nozzle size can now be set up to 1.8 mm. Thanks to @bkerler!
Known Bug
Running a selftest with damaged or unplugged fans shows a “Fan is not spinning” error instead of a failed selftest.
Release notes:  https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.3.3
Napsal : 27/05/2025 4:33 am
2 lidem se líbí
