[Résolu] Under extruding and Clicking/ extruder gear
RFT2112
(@rft2112)
I have used my Core one to print numerous prints with no problems out of the box.   Randomly, a few days ago, I noticed a clicking sound coming from printinghead.  Did some research and figured I would do all the recommended things.  cleaned nozzle, cleaned and made sure extruder gear isn't clogged, ran gear calibration, made sure no obstructions in feeding path to nozzle.  Did't do a cold pull as not familiar in doing on.  I have tensioned and re tensioned  the  idler screws many times.  I can get it close to running good but on faster extrusions in clicks and slips a couple times during the faster movement.   Been testing running stock benchy pre loaded print.
Here is a video of whats happening.
Core one
This may not be related but this started happening after latest update.
Publié : 28/04/2025 4:15 pm
1 personnes ont aimé
davidr91
(@davidr91)
RE: Under extruding and Clicking/ extruder gear
This is marked solved - curious what was the solution for you?
I have a very similar problem right now and haven’t been able to find anything that solves it
Publié : 05/05/2025 10:51 pm
RFT2112
(@rft2112)
Posted by: @davidr91
  Hi David,
   The under extrusion/clicking started happening after changing from stock .4 HF brass nozzle to a Prusa E3D Obxidian .4 nozzle,  an MK4 nozzle.   I had about 30hrs or so of successful prints using the Obxidian .4 nozzle printing PETG and PLA.  The clicking started happening  while using Jesse Premium Golden glitter filament.  I did all the usual per the suggestions from the forum in previous posts.  I ended up putting back the stock brass .4 HF nozzle and have been happily printing since.   Only one failed print and that was using the Golden glitter filament again....I think something is weird with that roll because I am using another roll of glitter filament from Jesse Premium and it is printing fine.   What I learned,  and I know better from being a machinist for the last 35 years, is if it aint broke, don't fix it.  lol.  saying that, I haven't put the E3D nozzle back in.
Publié : 06/05/2025 12:16 am
Print_Fandango
(@print_fandango-2)
Membre
I have the same noise, but it is very intermittent and almost impossible to reproduce. It is a random click and it drives me absolutely crazy...what is the solution?
Publié : 14/06/2025 3:50 am
Raaz
 Raaz
(@raaz-2)
Posted by: @print_fandango-2
What material and only on first layer or also later into a print?
For some data: go into the menu - user interface - footer -> set the unused slot to "heatbreak".
I had some extruder skipping, when using my 0.25 mm nozzle and printing with some negative Z-offset. With the door closed, the heatbreak went up to 39°C (PLA), which was too hot to push PLA through the small nozzle.
Two solutions: open the door (a little gap was enough for me) and/or check the command in the custom G-Code for the filament settings. I currently forgot which one it is, but there's a one-liner to set the heatbreak target temperature. For PLA, it's set to S36, so 36°C. Putting in S32 helps a lot in my case, since the heatbreak fan was only spinning at 70% and had some headroom.
My room is at 22-23°C. If you're printing PLA in a warmer place, the heatbreak might struggle with the 0.4 mm nozzle and without the negative Z-offset.
Publié : 14/06/2025 5:38 am
BrandlarAK
(@brandlarak)
Membre
i think thats what my printer is doing, very frustrating.  I switched my nozzle back to the .04 stock nozzle and its still doing it.  it will print the first ten layers or so fine, then it will start messing up.
Publié : 24/06/2025 4:32 am
Biomech
(@biomech)
When extruder is skipping it's usually because of low temperature. Hotend doesn't melt material fast enough and causing temporary clogs. Increase hotend temperature (or slow down prints) and it should be fine.
Publié : 24/06/2025 1:36 pm
Raaz
 Raaz
(@raaz-2)
Alternatively, heat creep due to door being closed. Activate the heatbreak temperature via the display: settings - > user interface - > footer - > free slot: heatbreak.
My extruder starts skipping with PLA at around 40-42°C.
Publié : 24/06/2025 2:16 pm
Scotttomo
(@scotttomo)
I had a similar issue that only presented itself at a certain layer height. It just clicked at random times and I couldn't work out what was going on. It wasn't until I let it run for a while that I noticed it had stopped extruding filament. After some cold pulls, and some advice from support, it continued to happen and I gave up with support around 9pm. After further investigation it turned out that the idler tensioner just needed increasing very slightly and its now not happened since. My only conclusion was that the filament was getting too warm after a time and became too soft for the extruder to pull the filament to the hot end? This is just a guess though as I'm still learning what's what. Hopefully it helps and good luck.
Scott
Publié : 02/07/2025 10:41 am
Ckobar
(@ckobar)
Maybe this helps.    https://www.printables.com/model/1072020-mk4s-bogie-idler-main-plate
solved my problems with TPU completly.
Publié : 03/07/2025 7:24 am
tabicat
(@tabicat)
Posted by: @rft2112
This has been my same exact experience.  I thought I was doing myself a favor by buying a fancy nozzle, but I just made things worse.  You can buy two brass nozzles for the price of one obsidian nozzle.  It's just not worth it.
Publié : 13/12/2025 7:03 pm
2 personnes ont aimé
RFT2112
(@rft2112)
As originally posted, I went from a high flow stock brass nozzle to a non hi flow obxidian nozzle and I think that was a big part  of the problem.
Just last week I was printing and started getting the clicking again with stock brass nozzle.  I took everything apart to clean and remember I bought another obxidian nozzle, except this was a high flow.  Put in the HF Obxidian after cleaning the everything since I knew I was going to print some ASA.   Worked great!
Publié : 13/12/2025 11:15 pm
Posted by: @rft2112
I only use hardened nozzles for everything. I have HF Obxidian and DiamondBack. I rarely use the Obxidian except for large PETG prints that can take advantage of the HF geometry and if it saves me more than 1hr of print time. Sure the DiamondBack is $130 but it will never (I hope) wear out. Brass nozzles to my mind are consumables/disposable so I don't see the point. Certainly can get V6 brass nozzles for very cheap but I change nozzles a lot, print a lot of abrasive filaments and V6 nozzles are a PITA.
Of course once the INDX arrives then my nozzle collection is more or less useless.
Publié : 13/12/2025 11:20 pm
Mac-N4MCC
(@mac-n4mcc)
OI will suggest two things...I did wrong. Double check and make sure that the really thin washer is still behind the gears. It is easy to lose and miss. They are available on Amazon. #2, make sure the tubv is still over the long grub screw at the bottom of the idler arm. Yep, drop it off once. They are not available on Amazon if you lose it!
Extra HAM (and eggs some say) Radio - N4MCC
Publié : 10/01/2026 11:21 pm
andyjessop
(@andyjessop)
Membre
Just to add my own experience to this. I'm now intermittently experiencing the clicking as described in OP's video. I haven't changed anything since building the machine, so using the default nozzle. About 30 hours use. Using "PLA Pro" from Elegoo.
Don't know if it helps, but the clicking continued for a few layers and then stopped. I will try to update here if I experience it again.
Washer and grub screw still look fine (from comment above).
Publié : 24/02/2026 2:03 pm
