Setup Feedback
Mukluk Actual
(@mukluk-actual)
Setup Feedback
Mostly a good experience, but...
  1. The LCD ribbon cable could be at least a centimeter longer to make it easier to connect. Same with the other wire.
  2. There's a little too much interference between the back case of the LCD and the ribbon connector; I had to file off some of the plastic from the case to make it easier to line up the connector.
  3. The filament spool holder was assembled with the seam *up*. It should be assembled with the seam *down* to remove a point of friction. Minimizing tension on the filament is particularly important with flexible filaments like TPU. You can re-design the part so that it's obvious to the assembler which side of the spool holder should be *up.*
    Other than that, so far, so good! I love the much smaller footprint compared to my Mk4s with enclosure.
Publié : 23/05/2025 11:32 pm
2 personnes ont aimé
