Rear Stepper Motor for Z Axis not moving up evenly
mlbellezz
(@mlbellezz)
Utenti
Just got my CoreOne, went to do my first print and I noticed it started printing way to high off the bed. I stopped the print and reset the printer. When the bed reset its Z axis it didn't move evenly leaving the rear portion of the bed lower then the rest and causing the front two to get jammed because of the torque put on it. Manually adjusting the Z Access in the control settings reveals that the Rear Motor doesn't seem to move the bed up at all anymore.
Not a great start, and no clue whats loose or what needs to be adjusted.
Postato : 07/02/2025 11:02 pm
mlbellezz
(@mlbellezz)
Utenti
TeamD3dp
(@teamd3dp)
I would reach out to support immediately.  It seems to me that this could be as simple as a poor connection at the control board that could have a trivial fix, or a damaged wire, bad stepper, or board itself. On such a new product, and one that is fresh out of the box, the best thing is to go directly to support for guidance.  They'll want to know if there is failed hardware so they can quickly respond with part or printer replacement.  If it is a simple fix they're better equipped to provide good advice.
-J
Postato : 08/02/2025 1:50 pm
mlbellezz
(@mlbellezz)
Utenti
RE: Rear Stepper Motor for Z Axis not moving up evenly
Thanks, Yeah I have opened a case. It's strange occasionally it will work fine, I am currently halfway through a 3 hour print no problems, but to get it started it failed to raise the bed, then the Z axis auto leveling failed so it ran the Z Axis Calibration again and then it worked. Support has asked me to check the connection as well. I figured documenting this hear in case anyone else has this issue I can post my resolution once its 100% fixed.
Postato : 08/02/2025 9:26 pm
1 persone hanno apprezzato
Morpheus90
(@morpheus90)
Utenti
For me the same issue was caused by a missassembly. My heatbed cable was not guided beneath the rear trapexoidal nut as expained in chapter 4 Step 30 of the assembly guid (version (1.00)).
Furthermore I lossened an retightened all scrows connected to heatbeat arms. Hope that helps someone 😉
Postato : 10/05/2025 6:00 pm
Daixiwen
(@daixiwen)
Utenti
I had the same problem on a newly assembled Core One. I managed to print two benchies, but after that began having problems with the rear z motor. Sometimes it would start jamming, and would only move down, not up, as you can see in this video: .
Like you it could print fine for some time and then suddenly begin jamming and printing way above the bed.
After reading this thread I double checked the connections, and they seemed fine, but I was convinced it was a mechanical issue because I could also feel when unscrewing the trapezoidal nut and turning the shaft by hand that sometimes there was a strong resistance, in one direction only. I contacted the support on chat. They were very helpful and after a couple of videos to show the problem they sent me a new rear z motor. My printer has worked flawlessly since that, so I definitely recommend anyone having the same problem to contact them.
I don't know what is the defect in the first stepper motor, but as Prusa didn't want it back I may try and open the gearbox one day to see if anything looks damaged.
Questo post è stato modificato 1 month fa da Daixiwen
Postato : 12/10/2025 8:21 pm
