[Rozwiązany] Print and hotend fans self-test failure
First Name Last Name
(@first-name-last-name)
Today finished assembly of my Prusa CORE One, but appeared that self-test of print and hotend fans fails. And what is more strange that if I unplug print fan then the hotend fan passes the test. Checked logs, and I see that there is no reading of RPM of both fans during self test. But what is more interesting that if I preheat the nozzle and go to sensors in the menu, It looks that there is a reading of RPM for the hotend fan. Has anybody faced with smth similar?
Opublikowany : 22/04/2025 6:28 pm
lancer enkor
(@lancer-enkor)
RE: Print and hotend fans self-test failure
Mine also failed after assembly. Then I upgraded the firmware to 6.3.2 and the problem disappeared. But I did not check the logs, so I don't know if it was the same problem.
Posted by: @first-name-last-name
Opublikowany : 24/04/2025 11:06 am
I did the update to 6.3.2, but unfortunately the situation is the same. The support proposed to replace 2 fans and a love board.
Opublikowany : 24/04/2025 11:39 am
Thanks to Prusa support, the replacement was delivered very fast. After replacing the parts its appeared that the print fan was faulty. After opening the faulty fan, I found that there is a soldering defect there. The RPM wire looked short circuited with +5V. Problem solved, now I am enjoying  my prints.
This post was modified 10 months temu 3 times by First Name Last Name
Opublikowany : 29/04/2025 10:48 am
1 ludzie polubili
