[Gelöst] Filament stuck in feed tube
BJ Klingenberg
(@bj-klingenberg)
Mitglied
I got my Core One last week and have had good success with prints to far.  Today as I went to change a spool, the filament broke off where it enters the machine.  I've unscrewed where the tube meets the print head and pushed on both sides with some other filament but it won't budge.  Do I need to take the machine apart to free the filament?  Is there a feeder above where it enters the machine? Any help appreciated.
Best Answer by Diem:
If the length of filament inside the tube is still intact you need something a little wider than your filament with a blunt end.  Disconnect he tube at the print head and temporarily remove the bend.  Push the filament through with your blunt ended implement until enough protrudes for you to grip...
If it is not in one piece or if it breaks again you will have to remove the whole tube, straighten it and blow through.
Examine the extracted filament - is it tacky or dusty?  If so you may need to clean it.  If it is OK, try bending it, damp PLA is very brittle but can usually be resurrected by drying.
Veröffentlicht : 12/06/2025 12:02 am
It's not clear - are you trying to remove a stub from the printhead or do you have a length broken off in the flexible tube?
The cause in either case is likely to be damp filament.
Veröffentlicht : 12/06/2025 10:00 am
BJ Klingenberg
(@bj-klingenberg)
Mitglied
RE: Filament stuck in feed tube
The filament is stuck in the flexible tube.
Veröffentlicht : 12/06/2025 1:52 pm
Posted by: @bj-klingenberg
Is the filament still visible in the short piece of tubing directly at the printer's input, right above the spool? If so, you should be able to pull out that tubing (it's a separate short stub), grab and hopefully pull out the filament from there.
If this does not work, you might have to take off the right side panel and open the housing of the filament sensor (which is mounted right above the filament input tube). Sounds like a filament fragment might be jammed inside the sensor.
Getting at the filament sensor is a bit of a fumble -- you will have to remove the screws which hold the orange carrying handle, side panel and filament sensor together, and then pop out the plastic rivets on the right side panel to remove that. See the kit assembly instructions to know what to expect: https://help.prusa3d.com/guide/7-bodywork-electronics_835530#866874
The kit instructions also give a good idea of what's going on inside the filament sensor: https://help.prusa3d.com/guide/7-bodywork-electronics_835530#844901 and subsequent steps.
Veröffentlicht : 12/06/2025 2:33 pm
Veröffentlicht : 12/06/2025 5:55 pm
BJ Klingenberg
(@bj-klingenberg)
Mitglied
That's what I had to do.  Thanks for the help!  It's working again.
Veröffentlicht : 12/06/2025 10:10 pm
chuck c
(@chuck-c)
Mitglied
I've assembled my Core One a few weeks ago. I have had this happen a few times due to brittle, undried PLA filament. If mid-print and detected by myself or the filament break sensor I manually pushed new filament into the feeder tube maintaining some pressure until the nextruder grabbed to feed the filament on its own. If this happened at the end of the print and was not too concerned about filament waste I did a filament load, purging until the nextruder grabbed the filament. At this point I unloaded the filament.
Diese r Beitrag wurde geändert Vor 3 months von chuck c
Veröffentlicht : 14/12/2025 2:20 am
KW
 KW
(@kw-2)
I have the same problem. In my case, the filament broke twice in the PTFE tube. It is also jammed and I can't get it out. Apparently, the Prusa has a weakness with transparent PLA filament, even though it was dried long enough. Unfortunately, I couldn't find the PTFE at Prusa. What are the dimensions of the tube? Where can I still buy it?
Thank you.
Veröffentlicht : 16/12/2025 9:04 am
Transparent filament is among the least problematic - next are translucent and black, then mid-range colours and the trickiest 'regular' filaments to work with are pastel shades and white...
If the trapped filament is damp and comes from the centre of a spool it is sometimes set into a relatively tight curve so that when the tube is straightened the filament ends jam because the broken ends try to dig-in.  Curve the tube to match the shape the filament wants to adopt and it should once more be free to move.
It seems your filament got unusually damp; if, like me, you live within walking distance of the sea (or similar water) on a lee shore you will have to make drying your filament a priority and for bigger prints, ones that take long enough for a dry spool to absorb too much moisture, you may need to work from a dry-box.
Veröffentlicht : 16/12/2025 4:12 pm
