Failed Z axis calibration after mk4s -> Core One upgrade
jhawk28
(@jhawk28)
Membre
What sort of things should I look into for troubleshooting why the Z axis fails calibration? It seems to make a grinding sound. It is able to move the bed up to the top.
Publié : 05/07/2025 10:55 pm
Tinker
(@tinker)
Membre
RE: Failed Z axis calibration after mk4s -> Core One upgrade
Check if the nozzle is actually hitting the build plate. I had to lower the nozzle a bit to pass the Z axis calibration.
Publié : 07/07/2025 9:10 am
jhawk28
(@jhawk28)
Membre
Yes, that was the problem.
Publié : 11/07/2025 1:18 am
Lance Luther
(@lance-luther)
Going to piggyback on here as I am having the same issues and tried to lower the nozzle but no luck. I have tried adjusting the trapezoidal nuts and even have a level to check the true of the bed and everything looks good but just will not pass. Any ideas on what else it could be?
Publié : 19/07/2025 11:55 pm
Arne
 Arne
(@arne-3)
Membre
Ensure the correct orientation of the trapezoidal nuts.
https://help.prusa3d.com/guide/4-heatbed-assembly_835514#842888
https://help.prusa3d.com/guide/4-heatbed-assembly_835514#842942
Publié : 20/10/2025 2:03 pm
