core1 řešení problému
orel skalní
(@orel-skalni)
ahoj
mám prosbu.
Stavím core1 a na horním uni profilu přímo na přírubě mě chybí závit.Sem mimo a něco sem přehlédll nebo je to vada dílu?
děkuji
děkuji
Respondido : 22/01/2026 3:21 pm
Posted by: @orel-skalni
Hi, I have a favor to ask.
I'm building a Core1 and on the upper UNI profile, right on the flange, I'm missing a thread / tapped hole. Am I overlooking something or is this a defect in the part?
thank you
I assume you mean the end of one of the frame profiles, where it gets attached to the adjacent profiles to form a corner? While the length of the frame pieces obviously varies, and pieces of the same length may have different holes or cutouts along their length -- the ends are all shaped identically. So if one of the profiles is missing a hole where all the other profiles have one, it is probably a manufacturing defect.
Respondido : 22/01/2026 5:47 pm
orel skalní
(@orel-skalni)
RE: core1 řešení problému
hi Jürgen
Yes, exactly – it is the end of the frame profile forming the corner.
All other profiles have the hole in the same position, only this one is missing it.
I double-checked the assembly manual, so it looks like a manufacturing defect.
Thank you for confirming.
Respondido : 22/01/2026 6:40 pm
