Core one from MK4S upgrade Z axis trouble
Just finished upgrade from Mk4S to Core One and have failed just at first calibration tests. Z axis failed, restarted printer. When i try manualy move Z from menu, i can see that one motor (front right) turns in oposite direction than others, left and rear goes CCW, right goes CW. Do you have any idea?
Napsal : 02/08/2025 4:44 pm
RE: Core one from MK4S upgrade Z axis trouble
I would check the connections on the motor split boars underneath the printer. Probably there is a mistake in the order, causing one motor to be reversed. If you fix it, I'm sure it will pass. Maybe just try to manually get the bed level a bit before restarting the tests.
Napsal : 03/08/2025 5:38 am
