Belt came off after assembly
Alyssa
(@alyssa-2)
Hiii, I just assembled by Core One Kit, but the belt came off when I was increasing the tension of it... after I assembled it all.
Is there an easy way to access the Nextruder holder, so I can put the belt back through it, without deassembling everything?
Napsal : 07/06/2025 4:58 pm
darkmattermaker
(@darkmattermaker)
RE: Belt came off after assembly
Oof. I don't think so. You're probably going to have to go pretty deep to get the belt back in.
Napsal : 07/06/2025 5:06 pm
Alyssa
(@alyssa-2)
I think I managed to dismount everything attached to the holder and then reattach the belts, and mount everything back on again.
Didn't take too long, but hopefully I mounted everything on correctly (it seemed hard to get it back on).
Will see if it works tomorrow
Napsal : 07/06/2025 10:37 pm
Samodjy
(@samodjy)
I had the same issue today. After fixing the belts and reassemble the print head, I found this cute tiny rubber O-Ring laying under my print bed.. Does any one knows if it come from the printer or if it just pop in my printer by magic ?^^
I've rewinded the whole assembly manual but I didn't find any mention of this part.
Oring
Napsal : 08/06/2025 7:34 pm
darkmattermaker
(@darkmattermaker)
I believe that o-ring should be on the PTFE connector that gets screwed into the Nextruder. It goes on the thread side inserted into the Nextruder.
Napsal : 08/06/2025 11:01 pm
1 lidem se líbí
Samodjy
(@samodjy)
Yes! You're right! 😉
Thank you Darkmatter!
Napsal : 08/06/2025 11:12 pm
iftibashir
(@iftibashir)
well spotted!
Posted by: @darkmattermaker
Napsal : 09/06/2025 4:04 pm
