Bad Printing Area
Mou67
(@mou67)
Miembro
Bad Printing Area
i tried to rebuild the Printer but nothing helped at the beginning of my printing where i build it first time it was ok but then out of the sudden it started this
Respondido : 05/04/2026 8:50 am
jan.d.slay
(@jan-d-slay)
RE: Bad Printing Area
So, how can we help you?
Respondido : 05/04/2026 10:15 am
Mou67
(@mou67)
Miembro
what can it be that it makes this, is it a slicer setting that i missed or is it an building problem from my side i cant figure it out
Respondido : 05/04/2026 11:01 am
Antimix
(@antimix)
Hello,
In a CoreXY assuming the gantry has been assembled correctly, the belt tension is all. Too much and the plastic will break an even the belt could break, too less and the print will have bad artifacts.
THINGS TO CHECK:
- inspect all the belts and verify they are not starting breaking in a point.
- inspect all screws of the gantry and check they are firmly fixed.
- inspect that the plastic parts did not have any break
- inspect that the pulleys are able to roll horizontally and they do not swing.
- retune the belt tensions seriously using a mechanical tension gauge like the one I told here in the forum.
I strongly suggest to build the gauge, now more then in the past, since we have a Core One+.
Regards
Respondido : 05/04/2026 4:08 pm
