Unable to open PrusaLink webpage
Fated Filaments
(@fated-filaments)
Trying to switch over after having Octoprint problems, but no matter how I set up a connection from my Mini to my local network, I can't get to the starting webpage. My hardware is a bit out of the ordinary, for the Ethernet connection I'm using a Ethernet to wall outlet adapter. However for WiFi I have an old router set up as a repeater, then connected to the Mini by Ethernet cable. Each way works though as I am able to ping the Mini from my PC using its IP address.
Opublikowany : 04/12/2024 5:06 am
