"Send to connect" from Prusaslicer does not work unless "Print now" option.
If I select the first option, Print now, printer is ready and the bed is clean, the Gcode is exported, uploaded into Prusa connect, and the printer (MKS4) starts in a matter of seconds. If I however select the other printing options, "Add to print queue / Skip the queue", the file is shown in prusa connect and in the queue, however there is a text saying "the file is not on the printer. My prusa connect storage space is almost empty, and the flash drive inside my mk4s has 28GB free left. What am I doing wrong pls?
Napsal : 27/03/2025 3:24 pm
RE: "Send to connect" from Prusaslicer does not work unless "Print now" option.
Were you ever able to find a solution to this. I am having the same issue. I got IT to open the port up and can do everything but files transfer to the printer.
Napsal : 28/08/2025 4:09 pm
