Option to select/confirm extruder appears sometimes not other times
Ira S
(@ira-s)
I suspect I'm missing something simple, but still can't figure it out.
I use Prusa Connect to send jobs to my 5 head XL.  I do so via the dashboard and select the .bgcode file, which then gets transferred to the printer and run.
Sometimes, the printer puts up a screen allowing me to confirm (or perhaps change) which extruder to use. Other times it skips this step.
I like this extra step because it lets me know which print head(s) will be used (in case I screw up and forget to assign the correct one(s) while slicing.
How do I get this step to happen all the time?  Must be something simple, but I don't see it.
Thanks.
Respondido : 24/11/2024 3:54 pm
Ira S
(@ira-s)
RE: Option to select/confirm extruder appears sometimes not other times
Bump
Respondido : 26/12/2024 11:04 pm
LarGriff
(@largriff)
As near as I can tell, it seems to only ask for extruder mapping if I start a job manually.  It never asks about extruders when I put a job in the queue and let it start automatically.
Posted by: @ira-s  Sometimes, the printer puts up a screen allowing me to confirm (or perhaps change) which extruder to use. Other times it skips this step.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 10/01/2025 1:54 pm
Ira S
(@ira-s)
Posted by: @largriff
 This is true, but the printer also used to (sometimes) also confirm extruder mapping when adding a job to the queue.  I heard back from Prusa support, and apparently it will also ask if the default extruder is specified when slicing. Haven't confirmed that.
Respondido : 11/01/2025 5:30 pm
