No lan access
Elg
 Elg
(@elg)
No lan access
Hi guys,
I used to operate rpi zero 2W with prusaLink without any issues since I installed it. However a one day the printer started to display No Lan Access on the display and I'm not able to manage it back to work.
I tried to reinstall prusaLink 0.81 (latestl), with correct SSID/Pwd credentials few times, but without any success. To check if the wifi on rpi zero is ok I installed Rpi OS and the machine was online. I also moved rpi zero from the printer to avoid low wifi signal issues.
Now I don't know how to solve this. The only difference I have spotted is, that my router changed IP for the rpi zero - but reinstalling prusaLink from the scratch should solve it.
Any idea what could be wrong? Thanks!
Napsal : 02/12/2024 7:05 am
tcengineer
(@tcengineer)
RE: No lan access
I'm having the same issue, but with a Zero W 1 RPi. Did you find a solution? Mine is a fresh install so I have never succeeded in having it connected to the internet.
Napsal : 10/12/2024 9:37 pm
AlexKots
(@alexkots)
RE: No lan access
I had the same problem, today (23/12/2024) I saw this message. And while searching for an answer in the web, the info changed to "Prusa Link OK" showing as IP 192.168.165. But I had given as IP an other (.19) by reserving this address to the router setup, assigned to the printer MAC Address.
I loged in to the router, where I found that the printer had a new MAC Address, so the router assigned to it one of the "free" IPs. I had also assigned a url to the printer, but the Chrome could not be connected (message: This site can’t be reached). So I logged in using the new IP.
So it seems that the Zero "lost" the setup, and somehow it used a new MAC Address
Napsal : 22/12/2024 12:32 am
Elg
 Elg
(@elg)
RE: No lan access
Still no solution found. I set IP address, which was assigned at the begining and prusaLink used to be working with, as static in my router. Again did a fresh installation, but still the same result.
Napsal : 14/01/2025 7:58 pm
Coolbeanz
(@coolbeanz)
RE: No lan access
Having the same problem here. RPi Zero 2W, fresh install of Prusalink 0.8.1. I've re-imaged the SD card probably a dozen times with the correct wifi credentials, each time it results in a "No Lan Access" message.
Napsal : 05/03/2025 12:13 pm
aasbakk
(@aasbakk)
RE: No lan access
I have the same issue on my Mk3S+. Bought a RPi Zero 2W, and installed Prusalink 0.8.1. Wifi-credencials are correct. Fifth time trying now, but no luck.
Has anyone found a solution?
Napsal : 26/04/2025 8:19 pm
aasbakk
(@aasbakk)
RE: No lan access
I downloaded the previous Prusalink version (0.7.2). This works nicely. Would like to upgrade to 0.8.1, but it seems there's a software bug in that version.
0.8.1 has been out for nearly a year, so maybe a fix should be made?
Napsal : 26/04/2025 8:50 pm
Coolbeanz
(@coolbeanz)
RE: No lan access
For me, the solutions was to stop wasting my time and effort wrestling with a product the manufacturer clearly doesn't want to support, and buy a P1S. Should have done it ages ago. Tripled my print speed and I can print from the network with no hassles. My mk3 is now gathering dust.
Napsal : 27/04/2025 2:46 pm
Elg
 Elg
(@elg)
RE: No lan access
Didn't try older version. But the funny thing is, that for me it accidentally stopped working in during the regular use and I am not able to get it back to work with the same setup. Anyway, it is nothing important that would limit my use of this still great printer.
Napsal : 28/04/2025 7:13 am
AlexKots
(@alexkots)
RE: No lan access
I found a method to assign static IP to W2 Zero:
https://forum.prusa3d.com/forum/postid/731514/
It is working without any plroblem, never missed the connection.
It can be accessed by the IP or the url name you have assigned to the RPi Zero 2W
Version is 0.8.1
Napsal : 28/04/2025 5:03 pm
1 lidem se líbí
aasbakk
(@aasbakk)
RE: No lan access
Thanks 😀
Ill look into this
Napsal : 28/04/2025 9:12 pm
Aamer
(@aamer)
RE: No lan access
Hi everyone, I wanted to share a fix for the "NO LAN ACCESS" error I recently encountered with my Prusa MK3S+ and Raspberry Pi 3B.
I’ve been using this setup for months without issue, but after moving to a new apartment (i.e. new network router) and updating to PrusaLink v0.8.1, my printer started losing its network connection every 2–3 days. A reboot would fix it temporarily, but the error always returned.
I eventually discovered the culprit: IPv6 conflicts. Whether it was the new router or the Pi software, IPv6 was causing the connection to drop. I found that completely disabling IPv6 and forcing the Pi to use IPv4 fixed the issue—my connection has now been rock-solid for over two weeks.
Important Note on the Fix: Initially, I tried disabling IPv6 via sysctl.conf, but the Pi's Network Manager eventually overrode it. To truly force it off, I had to modify the cmdline.txt file. If you are having similar issues, check your router settings to see if your Pi is using an IPv6 address. If it is, try the cmdline.txt method to disable it!
Napsal : 24/01/2026 11:22 pm
3DPrinTek
(@3dprintek)
RE: No lan access
Hi, my solution was to use an older version of the raspberry imager... Exactly version 1.8.5 as it was shown in the knowledgebase.
Also make sure to retype the wireless password if you write more than one SD card ... On the second I checked it and it showed gibberish...
Hope this helps.
Best wishes Richard
Napsal : 04/03/2026 11:06 pm
1 lidem se líbí
Aamer
(@aamer)
RE: No lan access
Hi @3dprintek, thank you for sharing your solution. I think my approach to disable IPv6 did not fully resolve the problem (it reappeared again after several weeks). So now I am very curious about your solution. You've mentioned that in the knowledgebase it shows to use version 1.8.5 of the raspberry imager? Do you mind sharing a link to that knowledgebase page? I would greatly appreciate that
Napsal : 30/04/2026 5:52 pm
_KaszpiR_
(@_kaszpir_)
please see https://forum.prusa3d.com/forum/prusa-connect-prusalink/prusa-link-raspberry-pi-imager/#post-789426
sou can also totally disable IPv6 on the rpi via commands (you need to do it only once)
sudo su -
echo "net.ipv6.conf.all.disable_ipv6 = 1" >> /etc/sysctl.conf
echo "net.ipv6.conf.default.disable_ipv6 = 1" >> /etc/sysctl.conf
echo "net.ipv6.conf.lo.disable_ipv6 = 1" >> /etc/sysctl.conf
and then rebooting the raspberry machine.
Older RPI Imager can be downloaded from their official release repo https://github.com/raspberrypi/rpi-imager/releases
Napsal : 30/04/2026 7:00 pm
