ESP32-Camera is not seen in Prusa Connect (Miroslav Pivovarski custom hardware)
Mariusz
(@mariusz-2)
Hello all
What could be the reason that after configuring the ESP32 camera according to Miroslav Pivovarský's instructions and entering the token from Prusa Connect, I can see the camera in http://prusa-esp32cam.local/ but it does not appear in the Prusa Connect window?
Best regards
Mariusz
Opublikowany : 02/07/2024 10:07 am
Mariusz
(@mariusz-2)
RE: ESP32-Camera is not seen in Prusa Connect (Miroslav Pivovarski custom hardware)
I would like to add that in Prusa Connect I can see Wi-Fi IPv4 address; Wi-Fi MAC address;Wi-Fi SSID address but the snapshot is NOT available,
Camera is connected to my WiFi and as I mentioned before and I can  see snapshots http://prusa-esp32cam.local/ .
Any idea how to solve it?
Best regards
Mariusz
Opublikowany : 02/07/2024 1:03 pm
_KaszpiR_
(@_kaszpir_)
are you sure the printer is reporting as online? if not then preview from cameras will not be visible.
Opublikowany : 02/07/2024 6:26 pm
Mariusz
(@mariusz-2)
Yes. The printer is online. I am using Prusa 2.8.0 so I can directly check status of the Printer.
I am using Firefox web browser as a default. Win 10.
Camera status in prusa-esp32 cam:
Status: Connected
SSID: I_8FA38D
Signal: 82% / -59dBm
IP Address: 192.168.0.13
mDNS: http://prusa-esp32cam.local
Regards
Mariusz
Opublikowany : 03/07/2024 7:11 am
Her MannF
(@her-mannf)
Hello, I have a similar problem since updating from 1.0.3 to 1.1.0-rc2.Yes, I asked the question on GIT but didn't get a response.
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam/issues/53
I have tried several times with two cameras of the type: https://www.amazon.de/gp/product/B0CXXYGNL4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1These run very smoothly with firmware 1.0.3. To stay up to date, I installed FW 1.1.0-rc2 in the cameras. The cameras start and log into the WiFi. When connecting to Prusa Connect, the cameras do not continue and the following error message is displayed in the log: Connection to domain failed! Error: -1 - ERROR - Generic error: 0 ,BA:Waiting for first connectionIt is also interesting that the NTP synchronization does not work. The error message appears:Waiting for NTP time synchronization:System time: 0000-00-00_00-00-00Both cameras work fine with FW 1.0.3.I also did a complete reset via pin 12 to GND and then deleted the ESO32 Flash and Download Tools.Does anyone have an idea how I can continue the search for the cause?
Hello Mariusz, if you put a memory card in the camera you can load a log file.
Please take a look to see if there is any interesting information in the log file.
This post was modified 2 years temu 2 times by Her MannF
Opublikowany : 26/07/2024 1:44 pm
theamzngq
(@theamzngq)
Same issue here, flashed 1.1.0.  All steps seem to have worked fine, I can see the snapshot in the cam's web interface, copied token, etc.   Just don't see it show up in Connect.
Opublikowany : 28/08/2024 5:15 pm
theamzngq
(@theamzngq)
Nevermind!  After about 15 mins, the camera finally showed up in Connect.  Didn't realize it would take quite so long...
Opublikowany : 28/08/2024 5:17 pm
Her MannF
(@her-mannf)
Mit Version 1.1.0 ist das Problem behoben - danke
Opublikowany : 06/09/2024 5:08 am
