Prusa Slicer Application / HTTP Transient Error port 443 Time out at Startup
Jtee
 Jtee
(@jtee)
Hello everybody,
am working on deploying Prusa Slicer for a School and running into this error at startup of the PrusaSlicer Application (Running on Windows 10/11)
Seems to be a proxy setting. If this is the case, where can proxy settings be made perhaps on file level, i can not find any setting in the application itself.
Kindly see screenshots below for further detail.
Thank you for your support.
Best Regards
Jtee
Napsal : 16/01/2025 9:42 am
_KaszpiR_
(@_kaszpir_)
RE: Prusa Slicer Application / HTTP Transient Error port 443 Time out at Startup
Talk to Prusa support and reference this issue https://github.com/prusa3d/PrusaSlicer/issues/13276
Napsal : 17/01/2025 8:11 am
ellymahina
(@ellymahina)
I’m also getting the same issue where PrusaSlicer shows a transient HTTP error and times out on port 443 at startup. It looks like it can’t connect to the server over HTTPS. Could be a firewall, proxy, or SSL certificate issue blocking the request on port 443. Still checking if adjusting network settings or allowing the app helps.
Napsal : 01/10/2025 5:19 am
