Wall mount the enclosure
jan
 jan
(@jan-9)
Is it possible to mount the enclosure directly to a wall?
I’ll mount the filament spools to wall over it.
Opublikowany : 13/03/2023 5:54 pm
JMH714
(@jmh714-2)
RE: Wall mount the enclosure
It may not be possible. Because of PSU mounted on the outside rear of enclosure.
Opublikowany : 15/03/2023 6:50 pm
Robin_13
(@robin_13)
Why not build a small shelf for the printer where you would mount it on the wall using a couple of shelf brackets?
I have not setup up my system yet but if the PSU on the back is an issue, maybe a pair of 2X4s as standoffs may work.  Would ensure that you can mount to the studs in the wall.  I wonder about the angular load on the frame.  May need a couple of brackets on the bottom for the load.
Opublikowany : 20/03/2023 10:42 pm
Sounds like the better option.
Posted by: @robin_13
Opublikowany : 21/03/2023 11:35 am
JMH714
(@jmh714-2)
Just be sure you have enough space for PSU's vent
Opublikowany : 21/03/2023 5:17 pm
