My Prusa Enclosure / MK3S+ / MMU2S Setup
dadunkindude
(@dadunkindude)
Having just finished the installation of my MMU2S onto my MK3S+, I wanted to show off the setup in case anyone is interested in setting up something similar.
I move every couple of years for work, so something mobile that could roll around and fit in different housing setups but still be durable was a must.  We settled on a utility cart, and the Prusa enclosure fits very nicely with a small amount of overhang on the back for the power supply.  The middle shelf we use for the active spools with the bottom for supplies.  Realizing a light source was needed, we installed a LED light strip off amazon on the angled surfaces of the enclosure beams, which is dimmable and really cranks out the lumens and illuminates the build space.  No need for a flashlight anymore!
Cart:  https://www.homedepot.com/p/Luxor-TC-32-in-3-Shelf-Utility-Cart-in-Black-TC211-B/303450963LED
Lights:  https://www.amazon.com/dp/B07XHLGSXN?ref_=cm_sw_r_apan_dp_2NA06K2Z4PR18V4EMT6J
This topic was modified 2 years ago by dadunkindude
Posted : 21/02/2023 4:32 am
JMH714
(@jmh714)
RE: My Prusa Enclosure / MK3S+ / MMU2S Setup
I have 4 enclosures and I planned to stack up two separated and then build an aluminum profile with wheels. The order I ordered aluminum profile will arrive on Friday. I hope everything go smoothly! 👍
Posted : 21/02/2023 6:11 pm
dadunkindude
(@dadunkindude)
Partial view of LEDs inside the enclosure
Illumination of buildspace (max brightness)
Front view (max brightness)
Front view (LEDs off)
Rear overhang
Posted : 22/02/2023 4:54 am
