My Prusa Enclosure / MK3S+ / MMU2S Setup
dadunkindude
(@dadunkindude)
Having just finished the installation of my MMU2S onto my MK3S+, I wanted to show off the setup in case anyone is interested in setting up something similar.
I move every couple of years for work, so something mobile that could roll around and fit in different housing setups but still be durable was a must.  We settled on a utility cart, and the Prusa enclosure fits very nicely with a small amount of overhang on the back for the power supply.  The middle shelf we use for the active spools with the bottom for supplies.  Realizing a light source was needed, we installed a LED light strip off amazon on the angled surfaces of the enclosure beams, which is dimmable and really cranks out the lumens and illuminates the build space.  No need for a flashlight anymore!
Cart:  https://www.homedepot.com/p/Luxor-TC-32-in-3-Shelf-Utility-Cart-in-Black-TC211-B/303450963LED
Lights:  https://www.amazon.com/dp/B07XHLGSXN?ref_=cm_sw_r_apan_dp_2NA06K2Z4PR18V4EMT6J
Positioning of lights inside enclosure
Front view of enclosure and cart with LEDs on
Good visibility of project (max brightness)
Front view of cart and enclosure with LEDs off
Enclosure overhang
Dieses Thema wurde geändert Vor 3 years von dadunkindude
Veröffentlicht : 21/02/2023 4:32 am
JMH714
(@jmh714-2)
RE: My Prusa Enclosure / MK3S+ / MMU2S Setup
I have 4 enclosures and I planned to stack up two separated and then build an aluminum profile with wheels. The order I ordered aluminum profile will arrive on Friday. I hope everything go smoothly! 👍
Veröffentlicht : 21/02/2023 6:11 pm
dadunkindude
(@dadunkindude)
Partial view of LEDs inside the enclosure
Illumination of buildspace (max brightness)
Front view (max brightness)
Front view (LEDs off)
Rear overhang
Veröffentlicht : 22/02/2023 4:54 am
