Is the Smart Box a dead project?
Seite 2 / 2
yaworski
(@yaworski)
Mitglied
RE: Is the Smart Box a dead project?
Posted by: @chris-hill
Posted by: @yaworski
What I wonder is how the SmartBox would control the control board for light strip and filtration system. There are three sockets on the control board. One for the strip, one for the filtration fan and the last one is probably for connecting the SmartBox in the future. It only has 4 pins, so it's not just a simple pass through. It may use something like UART or SPI maybe to control the logic on control board from the SmartBox.
The third socket simply provides additional connections for the fan and the LED.  They mirror the main fan and LED connections, and are controlled by the same switches.  So you can add additional lighting, for instance, without altering the wiring to the original LED strip.
https://forum.prusa3d.com/forum/user-and-hardware-mods/further-information-on-basic-board-and-psu-for-original-prusa-enclosure-for-filtration-unit-and-custom-led/#post-691565
Thank you.
As it's mentioned in the thread you've linked, pins for the RGB in the LED connector are not connected anywhere on the control board.
So this basically means that when (if?) they release the SmartBox in the future, the control board won't probably be used at all, but the LED strip and filtration blower fan are going to be connected directly to the SmartBox instead.
It should be fairly easy to just control the fan and LEDs from Raspberry Pi's GPIO (with some mosfets to switch 24 V from 3.3 V logic). With PWM output, one could control fan speed and RGBW lighting. I've not used Octoprint yet, but I think there are some addons for outputing PWM on Pi's GPIOs.
Veröffentlicht : 10/06/2024 2:33 pm
Matthew K
(@matthew-k)
Mitglied
have there been any updates here? It feels kind of strange being unable to remotely control the fan and lights.
Veröffentlicht : 14/10/2024 9:32 pm
Brian
(@brian-12)
I've actually found that having the light on its own manual switch is preferable to bring controlled by the printer.  Why.... well because 99% of the time there is no need for the light to be on, I only turn it on to check the print, then turn it back off.  Being on a manual button on the enclosure is super easy to walk up, flip the light on, then turn it off and walk away.  I think it's a pain in comparison to navigate thru the menus to turn it on it off.
The fan on the other hand needs to be controlled by the printer.  It works way better that way because it'll automatically turn it off when the print is done. I currently use a smart plug to control it, but you have to manually set a timer every print.
Veröffentlicht : 15/10/2024 12:06 am
MJ
 MJ
(@mj-4)
Just recieved the MK4S upgrade and the IO board. Trying to find time to dive into that.
Until now, Ive used the Home assistant Integration to turn on/off a relay that is controlling the fans.
When a print starts - so does the fans.
One fan filters the air in the enclosure - the other extracts air to provide a bit of negative pressure in the enclosure. They both have a HEPA/Carbon filter.
It may not be perfect, but so far it has ensured an odor-free room. Even when printing ABS or ASA.
Down the line, I would like to add some active enclosure heating. Nothing crazy - just to bring the enclosure temperature to a stable level a little faster than when just using the bed and extruder.
Veröffentlicht : 15/10/2024 8:13 am
Alex Richenderfer
(@alex-richenderfer)
Mitglied
is anyone aware if there has been any update thus far on the status of the development of the smartbox as of 2025?
Veröffentlicht : 10/09/2025 2:17 pm
Tonni
(@tonni)
Mitglied
The Smart Box is still listed on the enclosure project page, but there hasn’t been much word about its release lately. From what I’ve read, the idea is to let it connect with add-ons like sensors, locks, and even an LED strip light or RGB LEDs to give clear signals during printing. It would be a handy feature if it makes it to production, but until the team shares an update, nobody really knows whether it’s still moving forward or just paused.
Veröffentlicht : 02/10/2025 10:43 am
Walter Layher
(@walter-layher)
It's not dead, it just smells funny! 🙂
Veröffentlicht : 02/10/2025 6:05 pm
Milan Huf
(@milan-huf)
Mitglied
I tried to contact Prusa technical support, unfortunately according to them they don't know anything about this Smart box project. I thought of using the Extension board from the Core One printer - it is suitable for connecting RGB LED strip, white strip, fans. But according to Prusa support, this board will not work due to the printer firmware even though the MK4/s and Core ONE printers have the same motherboard.
Prusa also added a GPIO Hackerboar, where there will be partial automation of the HEPA filter and white LED strip. Unfortunately, they don't have more information on the website.
Veröffentlicht : 04/11/2025 2:46 pm
Sara taylor
(@sara-taylor)
Mitglied
The Smart Box is still being considered, though there is no clear timeline for completion.
Veröffentlicht : 19/12/2025 11:52 am
Rene
 Rene
(@rene)
Mitglied
The smart box is not longer mentioned on the product page 😞
Veröffentlicht : 10/02/2026 11:41 pm
Walter Layher
(@walter-layher)
If you need a similar functionality as the once announced Smart Box on your MK3xx/MK4xx printer with an enclosure, I would suggest reading up on OctoPrint and what you can do with it and the available plugins. This would be time better spent than on waiting for Prusa, considering that an eventual Smart Box won't come for free ... 🙂
Veröffentlicht : 10/02/2026 11:57 pm
Seite 2 / 2
