Advanced Filtration System
JonPointer
(@jonpointer)
Where can I get more information about the Advanced Filtration System add-on?  I couldn't find any information other than a small paragraph and a quick look in the video.  The video stated that it has a "HEPA filter with active carbon granules".  Does this mean it would eliminate the odors (or off-gassing) from printing ABS?  Also, is it a fan and filter system that is pulling air in through the various gaps in the enclosure and then exhausting through the filter in the side of the enclosure?  Lastly, are the filters a standard filter that is easy to source to replace?
Thanks!
Postato : 30/05/2022 4:59 am
1 persone hanno apprezzato
milosm
(@milosm)
RE: Advanced Filtration System
I'm interested in this as well.
Postato : 06/07/2022 2:27 pm
HEPA: High-Efficiency Particulate Air filter is a dust/smoke filtration standard and replacements are off the shelf parts (if you can find the right shelf). So a HEPA filter does not remove gasses as standard.
The addition of activated carbon does remove/reduce many gasses and presumably has been chosen/specified for common 3D printing exhaust components.
Postato : 06/07/2022 3:18 pm
