Printing soft TPU with original prusa enclosure
NelisW
(@nelisw)
Finished assembling the enclosure last night. It took a bit longer than Robert Cowan reported on YouTube. Now for calibration with new obxidian nozzles.
First job ahead is printing with soft-ish TPU. The challenge is getting the filament to the extruder but not via the PTFE tube.
There are no holes on the top roof to fit a connector/coupler (picture taken from below, inside) , Obviously I don't want to drill holes in my brand new $600 trophy enclosure!
It is possible to remove the top (4 screws & 2 connectors). Ideally, one should not remove the thing for every second print...
Any suggestions?
Publié : 15/08/2024 3:09 pm
1 personnes ont aimé
mvikman
(@mvikman)
RE: Printing soft TPU with original prusa enclosure
Dont really know if there's a lot of choices, other that drilling holes.
I'm just going to drill holes on the top for TPU feed, haven't gotten that far yet though, so don't know if I'll make holes on the steel top or on the acrylic sheet.
Publié : 15/08/2024 8:41 pm
NelisW
(@nelisw)
I feel tempted to put a variation of this drybox on top of the enclosure, feeding down through a coupler in the plastic window (it feels less gross drilling plastic than the steel).
https://www.printables.com/model/870347-drybox-for-prusa-xl-3030-extrusion
The using something like this to guide the filament
https://www.printables.com/model/733480-prusa-xl-soft-tpu-printing-modification
Comments?
Publié : 16/08/2024 5:59 am
Marc
 Marc
(@marc-9)
I used this before I had the enclosure: https://www.printables.com/de/model/718498-prusa-xl-soft-tpu-cable-clip-to-extruder-prusa-xl
It worked well with Polymaker PolyFlex TPU95-HF. Havent' tried any softer TPU.
I'm also interested in a viable solution to feed TPU in the enclosure. 😇
The most simple solution would be to drill a hole. But I can understand, that you don't want to drill in a 600$ enclosure. 😅
Publié : 16/08/2024 9:18 am
BaconFase
(@baconfase)
Remove that nearby rivet/screw, replace it with a blue festo or maybe just a short run of ptfe tube, and sneak the tpu through there?
Publié : 17/08/2024 4:55 am
carlmmii
(@carlmmii)
Alternate option -- modify the filament sensors so there's no longer any friction.
I've done this modification, for both the side sensors and the extruders, and there is now absolutely no issue pushing TPU through the PTFE tubes. Zero resistance any more from passing the sensors.
Publié : 30/08/2024 3:50 am
NelisW
(@nelisw)
Thanks for the link, will check it out!
Publié : 30/08/2024 5:19 am
pcgeekesq
(@pcgeekesq)
I did the mod at https://www.printables.com/model/860920-prusa-xl-magnetic-filament-sensor-remix-for-print/files that replaces the springs on the side filament sensors with magnets (and that adds couplers) and it works great with TPU.
I also added couplers to one of my Creality Space Pi dual-spool filament dryer and print TPU directly from it; the setup is shown below.
Publié : 04/11/2024 3:44 pm
