Longer Filament Sensor Cables
IBNobody
(@ibnobody)
I recently purchased a pair of these Molex Clik-Mate cables that are 600mm long.
https://www.mouser.com/ProductDetail/538-15135-0506
These cables have the correct connector footprint, but they are not wired like the cables from Prusa.
Mouser Cable Wiring (Incorrect)
  • Connector A Pin 1 - Connector B Pin 5
  • Connector A Pin 2 - Connector B Pin 4
  • Connector A Pin 3 - Connector B Pin 3
  • Connector A Pin 4 - Connector B Pin 2
  • Connector A Pin 5 - Connector B Pin 1
I was able to use a needle to pull out the terminal and wires and reconnect them as follows.
  • Connector A Pin 1 - Connector B Pin 1
  • Connector A Pin 2 - Connector B Pin 2
  • Connector A Pin 4 - Connector B Pin 4
  • Connector A Pin 5 - Connector B Pin 5
The cables now work as intended.
Postato : 05/01/2024 9:30 pm
2 persone hanno apprezzato
Brian
(@brian-12)
RE: Longer Filament Sensor Cables
Can you do a video of how you did it?
Postato : 19/01/2024 12:13 am
Raptor King
(@raptor-king)
Did you ever come across a male / female cable?  Id like to extend the existing cable and be able to easily disconnect them where the old and new cable couple.
Postato : 29/02/2024 12:17 pm
Scisok
(@scisok)
Raptor,
This model has links to lengthen the cables.  They parts are from Mouser electronics. Essentially, he took 2 female sockets and soldered them back to back and then used a 600mm male-male cable to extend them.  I will be trying the same.
https://www.printables.com/model/802662-xl-filament-sensor-relocation-mount
Postato : 16/03/2024 6:01 pm
1 persone hanno apprezzato
Raptor King
(@raptor-king)
Thanks!  Its fun to see that model referenced.  Its mine.  😀    When I couldn't find the right cable, I came up with my own solution.
EDIT: Extending the existing cable also meant that repinning wasn't required.
Questo post è stato modificato 2 years fa da Raptor King
Postato : 16/03/2024 6:52 pm
Scisok
(@scisok)
I'm laughing at myself.  Sorry I didn't pick up on that.  Your idea is the best I've found for a plug and play extension cord.
Postato : 16/03/2024 8:53 pm
Scisok
(@scisok)
Raptor,
I went and ordered the parts.  Mouser's prices went up $1 a cable by the time I put my order in.  I soldered the sockets up and hot glued and shrunk wrapped them.  No problem.  Thanks for a great idea.  Now I just need to figure the best location for my dry box now that I have some leeway.
Postato : 20/03/2024 10:33 pm
Raptor King
(@raptor-king)
Glad that worked out for you!
Postato : 30/03/2024 11:04 am
