Settings - crossing parameters - oozing problems
ByteC
(@bytec)
Hi guys,
I was trying to print a machine part, outer hull Greentec Pro, inner part Fiberlogy Fiberflex 30D. However the Fiberflex oozes a lot, and I have to find out the correct settings.
Nozzle type: 5x 0.6mm brozzl hardened steel, xl adapter
Below you can see the result. (The prime tower was damaged by hand for curiosity :))
As you can see, there was a lot of oozing, and the inner part was much worse.
As you can see, there are a lot of travel moves. I was the opinion I can avoid this with the correct printer settings. However it seems they get ignored.
Is there anything I can do to avoid travels inside the model?
Cheers,
Peter
Posted : 17/11/2023 8:42 am
