Really odd final layer issue
DANGT4
(@dangt4)
So I've had quite a few successful prints recently with my settings and the 0.4mm nozzle but then today I had this issue with the finish layer in the centre of this part (the sides are still printing for another 15mm).  What has caused this?!  I have the top at 5 and bottom layers set at 4 with infill set at 30% rectilinear and top and bottom layers monotonic.
[URL= https://hosting.photobucket.com/images/c214/DanR32/IMG_7404.JP G" target="_blank">https://hosting.photobucket.com/images/c214/DanR32/IMG_7404.JP G"/> ?width=1920&height=1080&fit=bounds[/IMG][/URL]
This is what it will look like when finished.
[URL= https://hosting.photobucket.com/images/c214/DanR32/Screenshot_2024-03-09_at_18.34.11.pn g" target="_blank">https://hosting.photobucket.com/images/c214/DanR32/Screenshot_2024-03-09_at_18.34.11.pn g"/> ?width=1920&height=1080&fit=bounds[/IMG][/URL]
Posted : 09/03/2024 6:38 pm
Zappes
(@zappes)
RE: Really odd final layer issue
I don't know if this could be an explanation - but I did have very similar effects when my heatbed thermistor started going bad. In my case, it could have been completely unrelated, but there is a temporal correlation and the issues went away when I installed a new thermistor.
My models on Printables
Posted : 10/03/2024 10:42 am
DANGT4
(@dangt4)
Thanks for the reply.  Daft question, do you mean the hotend thermistor?  I didn't think the XL had a heatbed thermistor.  Couldn't find any info about one anyway!
Posted : 10/03/2024 11:47 am
Zappes
(@zappes)
Ah, sorry, I once again failed to notice in which forum I'm posting - I somehow assumed this was an MK4. 🙂 Anyway, in my case, the problem was that the heat bed was hotter than it was supposed to be, which caused the bridges across my infill to sag. The result looked a lot like what you have there.
Perhaps try to reduce the heatbed temperature a bit? Or give a little more part cooling?
Posted : 10/03/2024 11:55 am
