Quick tip: Wipe tower failure fix
stratocaster
(@stratocaster)
Hey just a quick tip.  I was 5 hours into a 12 hour print and my wipe tower failed.  I have had this happen in the past and glue sticked it back in place with limited success.   I couldn't do that this time.   I was going to trash the print, because random filament was getting all over the print.   My wife suggested using painters tape.  I was able to match the height and it worked perfectly.   The tape was perfect.  It's soft enough for the nozzle to dip into if you don't get the height exactly right.
Just thought I would pass this along since it saved my print and could help others.
strato
Veröffentlicht : 21/06/2024 5:41 pm
Larry
(@larry)
RE: Quick tip: Wipe tower failure fix
I had a similar issue and a very large print, the wipe tower was not saveable.
So I eyeballed the level with some post it notes and that worked!
Veröffentlicht : 02/05/2025 8:36 pm
stratocaster
(@stratocaster)
Great idea.  I’ll have to remember that one.  anything to save a print!
Veröffentlicht : 03/05/2025 12:26 pm
Matthias U
(@matthias-u)
While these ideas are nice, I'd rather have a non-failing wipe tower. *sigh* specifically I'm trying to print a multi-hour delicate thing with .1mm layer height, without babysitting the printer if at all possible. So far zero luck, the thing always rips off at its base.
It'd help if you could print a chamfered wedge around the base …
Veröffentlicht : 06/05/2025 10:49 am
stratocaster
(@stratocaster)
Have you tried a bit of glue (Elmer’s glue stick) at the footprint of the tower before printing?  Works like a charm for me.  I found that after many many prints the surface of the stock build plate doesn’t hold the print as it did when brand new.
Veröffentlicht : 06/05/2025 12:44 pm
Matthias U
(@matthias-u)
Yes, actually. It helped somewhat, but a tower that detaches 80% into the print on average is not that much more useful than one that detaches at 50%.
Veröffentlicht : 06/05/2025 12:49 pm
