Problems in selecting the nozzle for support material
Didrik A. Voss
(@didrik-a-voss)
Utenti
I am printing a two-color object that needs supports and a brim. Nozzles 1 and 2 are the PLA colors; nozzle 3 is the support material (PVA in this case).
In Printer Settings: “Multiple Extruders”, I have set “Perimeter extruder” and “Support material/raft/skirt extruder” to 3. “Support Material- Style to Organic and “Top contact Z distance” to 0(soluble). In Filaments: I have set the filament to be PCA. I have also set “Supports” to “Everywhere” and checked “Brim”
When I slice the object, there is no indication that nozzle 3 is used – only 1 and 2. Both 1 and 2 are used to print the brim and the tower – not 3.
What am I missing?
Postato : 06/12/2024 11:16 pm
RE: Problems in selecting the nozzle for support material
I don't have an XL, but I have used multi material interfaces in dissimilar materials, with My  Mk3.9 and MMU3.
This model is one of the wings off 'Glory' by John Freund Racing in Printables ( as an example)
for Demonstration purposes I set filament 3 as BVOH, for supports (it was a spare extruder in this section of the model)
then in 'Print settings > MultiMaterial' I set filament 3 for supports and support interfaces
(ordinarily I would only set support interfaces when I am using PLA to support PETG or Vice Versa, but in this case that option didn't work as expected...)
I Suspect this allocation of extruder to support functions is what you are missing(see Below)
this knowledge base article, may help
https://help.prusa3d.com/article/support-settings-for-the-xl_681927
the original author of this model used Paint on supports and multi material painting, which may have a bearing upon why the support interfaces didn't seem to work as expected
Postato : 07/12/2024 12:03 am
Best to upload your 3mf project file.Zip compress it, then use the Attach file button below the post edit field. This way we can see your settings. I just did a quick test, and in my hands extruder 3 is used for supports, so I suspect there's something in your settings that is wrongly configured.
Postato : 07/12/2024 5:38 pm
