Print large projects of same material from several spools
M.J. Caboose
(@m-j-caboose)
I have a larger model constisting of several parts. I want to print it with a single color (PLA) ... so straight forward. When slicing the model I need apx. 2kg of filament in 3 days 🙂 ...
I have the XL multi tool (5) and was hoping that I am able to start with toolhead 1 and after the filament is gone it automatically switches to toolhead 2 (preloaded with another spool of the identical filament) .. But I was not able to find any settings to do this.
Most likely I just overlooked it, since it seems to be a common scenario.
I've set up the printer as 5-head printer and assinged the same material and color to all extruders ... I can chosse different extruders for different parts ... different extruders for different heights ... but I was not able to simply swap the tool after the filament is gone.
Does anybody have the solution for me?
Best Answer by FistoWutini:
Spool join is available now on the alpha firmware that just came out.
- Made by me -
Posted : 15/10/2023 1:06 pm
Papy_Yosh
(@papy_yosh)
RE: Print large projects of same material from several spools
From what I have read, it is not available yet. I saw few posts where users were asking for that exact function. My guess is that it will have to come from a PS update.
Posted : 15/10/2023 8:51 pm
Spool join on MMU3 would work, does the XL Multitool have spool join?
Joan
Posted : 15/10/2023 11:51 pm
I'm sure spooljoin will be along soon, it's too useful to ignore.  When I still used my MMU it was a great way to use up odd ends of filament as long as you didn't mind gaudy, candy striped prints.
Workaround:  First slice your project.  Slicer will report the amount of filament required so allow a buffer of around 5% and buy the next size up spool.  Alongside the usual 1kg spools I have 2, 2.5 and 3kg spools and 5, 8 and 10kg are readily available.  You may need to make spoolholders for the larger sizes and at some point you will need motorised holders but I expect up to 5kg to just work.
Posted : 16/10/2023 4:51 am
M.J. Caboose
(@m-j-caboose)
In the meantime I also contacted support for that one ...
Spool joining is not in the firmware of the XL in the moment ... But it is on the list with a quite high priority ... most likely even in the next version it will become available.
- Made by me -
Posted : 17/10/2023 6:52 am
FistoWutini
(@fistowutini)
Posted : 26/10/2023 3:14 am
M.J. Caboose
(@m-j-caboose)
Cool ... it is comming up 🙂 ...
But since I have still some quality issues I need to sort out together with support I will have to stick to the stable version for the time beeing. .. but it is good to hear that it will be in the next release 🙂
Thanks.
- Made by me -
Posted : 29/10/2023 9:46 am
CleverSquirrel
(@cleversquirrel)
This recent post discussion tells you how to find/use the alpha version on the XL: https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-general-discussion-announcements-and-releases/can-the-tool-head-change-automatically-when-filament-runs-out-on-one-head/
Posted : 29/10/2023 12:29 pm
