Bed very loud "Squeek" noise when dropping bed down during tool change.
Revel
(@revel)
My XL is making a very loud noise each time the bed lowers during a tool change. It doesn't not do this otherwise, including coming back up.
I've been trying to look up XL maintenance but not finding docs or videos on lube, where to, how to, etc... for the XL
Looking for advice on what is doing this and what to do.
Thanks
Opublikowany : 04/12/2024 4:27 pm
Brian
(@brian-12)
RE: Bed very loud "Squeek" noise when dropping bed down during tool change.
Did you try lubricating the lead screws?  They recommend a small amount of the Prusa grease.
First clean them with a clean paper towel. Then apply a small amount of grease.  You should've gotten a tool with the printer that screws onto the grease tube that has the shape of the lead screws on them.  If you can't find it no big deal just put a small amount on and then run the bed up and down.
Opublikowany : 04/12/2024 4:37 pm
