Z-Axis Not Moving Upward After Enclosure Upgrade
CummingsMA
(@cummingsma)
Utenti
I have experienced this twice: 1) After performing the enclosure upgrade, then 2) Finally putting the Sandwich and Buddy Covers back on. The Z-axis seems to lose its upward movement as if it no longer recognizes its position. Under Control > Move Axis > Z-Axis, it would go to the bottom, but not back up.  I have fixed this by repeatedly moving the Z-axis down to the bottom and continuing to dial it lower, with the mm increasing, and the XL making a complaining noise.  This seems to then set a new lower bottom coordinate. I then move the Z-axis back up as far as it will go.  I repeat this until I can get the Z-axis to get to the top position.  I can only do a little at a time, or else the XL will make a loud humming noise, and I have to reset it.  Is this a known issue?
NOTE: The enclosure upgrade proper is likely not the issue; however, the XL had printed fine before the upgrade. Reflashing the firmware (6.2.6) did not resolve the problem.  Also, I had printing to get done, so I left the board covers off after the first fix to do it, and everything printed fine (three days ago). Then, I put the covers back on this morning and had the same Z-axis issue.
Postato : 27/10/2025 7:20 pm
