[Gelöst] XL5T Enclosure Magnets
Macmagoo
(@macmagoo)
Upper magnets are not strong enough to hold the bellows up. I can get them to stay up but if I breath on them they collapse. Not what I expect from an expensive enclosure.
Veröffentlicht : 26/09/2024 11:37 pm
RadekP
(@radekp)
RE: XL5T Enclosure Magnets
Strange. Mine are holding the bellows strongly.
Are you sure that you mounted the magnets  correctly?
Veröffentlicht : 27/09/2024 10:40 am
Macmagoo
(@macmagoo)
I will take some photos of my upper magnet setup. I am absolutely certain they are as described in the setup documentation.
Veröffentlicht : 27/09/2024 1:35 pm
Macmagoo
(@macmagoo)
Veröffentlicht : 28/09/2024 3:15 am
RadekP
(@radekp)
It looks correct.
If you test the upper magnets by placing some metal object on the magnet - is it holding the object strongly? If you put the one umounted upper magnet assembly on the bellows - is it connected strongly? There must not be a space between bellows frame and the upper magnet assembly.
Veröffentlicht : 28/09/2024 3:35 am
Macmagoo
(@macmagoo)
The magnets hold a metal object just fine. The unmounted magnet sticks to the bellows just fine.
Veröffentlicht : 28/09/2024 3:43 am
RadekP
(@radekp)
Ok, so then it looks fine. Are both upper magnet assemblies aligned to the printer frame? Is the bellows upper frame attached to the both upper magnet assemblies without any space?
Veröffentlicht : 28/09/2024 3:50 am
Macmagoo
(@macmagoo)
I have sorted it I used the wrong screws on the upper magnet fixings. Working perfectly know. Thank you.
Veröffentlicht : 28/09/2024 4:02 am
