XL enclosure issue (with prusa connect) - Fan not starting
NoeG
 NoeG
(@noeg)
Bug / error report:
I just upgraded to 6.1.3, and the two prints that I started with prusa connect both had an issue about "fan not starting, check for debris, and cabling" (or something along those lines).
The print then starts after pressing "continue" (or ok?).
I then cancel the print, and the enclosure option in "control" is ticked off. I enable it again, it shows a "checking fan" message, then no error message, and enclose menu is ticked on.
I then restart the print via the printer menu, and no error message, and fan is working normally.
Respondido : 16/09/2024 7:14 pm
Stephen J me gusta
Stephen J
(@stephen-j)
Miembro
RE: XL enclosure issue (with prusa connect) - Fan not starting
I have the same issue - same error message.  I keep printing (as you did) but rather than cancelling the print, I just select the "Tune" menu and go down to "Enclosure" and activate it.  The enclosure fan then springs into life.  This is despite previously enabling the enclosure in the "Control" menu.
Posted by: @noeg
Bug / error report:
Respondido : 05/10/2024 5:04 am
Gilles buildmaster
(@gilles-buildmaster)
Same here. About 50-50 chance that it gives this error at the start of any given print. It then just prints without starting the fan after I acknowledge.
Then I can start the fan in the tuning menu without problem, like Stephen J indicated.
Feels like a software issue, a check value is set to tight, or the fan is not given enough time to spin up or such.
Respondido : 07/10/2024 6:54 pm
