Top Layer Problems
purpledread
(@purpledread)
Top Layer Problems
My Prusa XL have been printing great for the last month, since I got it, but all of a sudden I'm having problems with the top layer.
Any idea what the issue could be?
Opublikowany : 09/04/2024 2:37 am
XL beta tester for far too long
(@xl-beta-tester-for-far-too-long)
RE: Top Layer Problems
Same here, anything over 200cm and it goes BAD.  Small things come out perfect.
The above has been tried with several default Prusa XL profiles and all have issues with the last layers.
The first layer could not be any more perfect so don't try to pull off the princess and the pea thing.
I only changed top layers to 5, perimeters to 5.
The cooling was default 30%-50%, The temp was default at 240 after first layer.
Opublikowany : 18/04/2024 6:41 pm
Maybe it's art?
Opublikowany : 18/04/2024 7:03 pm
RE: Top Layer Problems Failed attempt #5
Perfect coming in on top layer #1.
Opublikowany : 19/04/2024 3:05 pm
But the next layers go garbage again. Reduce flow to 90%, not a lot of change, just junk.
Opublikowany : 19/04/2024 3:07 pm
Perfect first and second layers.
Opublikowany : 20/04/2024 12:42 pm
Infill perfect.
Opublikowany : 20/04/2024 12:43 pm
Bridging perfect.
Different filament and the top layer indisputably horrific.
Opublikowany : 20/04/2024 12:44 pm
I think Prusa boy needs another modifier differenct from fuzzy skin.  I call this one hair.
GARBAGE.
So how do I get my money back?  I could put two months salary to better use.  JO HELLO?
Opublikowany : 20/04/2024 12:46 pm
purpledread
(@purpledread)
Strange thing for me is that it's been working great for months and all of a sudden just the top layer seems to have problems.
Opublikowany : 20/04/2024 1:11 pm
It looks like warping, if you turn it over you will probably see adhesion problems - on an XL that suggests either a print-sheet in need of degreasing or you are printing in a draft.
Clean the sheet and try adding a brim.
Opublikowany : 20/04/2024 2:43 pm
purpledread
(@purpledread)
Bottom of the object is fine and I am already printing with a Brim. I cleaned the surface, but no change.
It takes a while to print the object. I'll clean it again and recalibrate over the weekend and try to print it again.
Opublikowany : 20/04/2024 3:24 pm
What filament is this?  Another cause that we don't see so often nowadays is out-of-spec filament - measure the diameter in a few places and average; if it's off enter the true diameter in Fialement Settings.
Opublikowany : 20/04/2024 6:57 pm
purpledread
(@purpledread)
I'm using BambuLabs Matte PLA. It's the same filament that's been working fine.
I did increase the temperature to stop warping. I'll mess around with that some more.
Thanks,
/Chris
Opublikowany : 20/04/2024 8:22 pm
