Tool crash with objects cancelled - mutli tool, multi-part print
So I'm happily printing along on the XL, still in testing mode really, exploring it's potential and getting to know this monster. Wife picks a multipart model so I set it up for a multi-color plate of parts. A little while into the print I realize the wrong extruder was assigned to a few parts (in reality it was a single grouped part but I split it to add a brim to the two small pieces which assigned them back to the default extruder). Anyway, no big deal, I'll just "Cancel Object" from the control panel (parts in blue circle; missed one and got the timing wrong which cancelled the two circled in yellow). Things progress normally for a few hours.
This is the model: Merry Christmas sign
- Tool 1 = Red
- Tool 2 = White
- Tool 3 = Black
- Tool 4 = Green
- Tool 5 = Gold (closest color I had for the skin, Santa will have a nice tan)
Of course, this being a new device I'm just getting to know, I can't stop returning to the room to watch. On one of these visits I'm watching and everything is just perfect. Then, BAM. Tool 1 finishes and then crashes into tool 3, the leds flash red and a tool crash detected message shows on screen. Interesting, I think out loud, then proceed to follow the instructions on the panel and reset tool 1 manually. XY re-homes and it picks and prints all other colors as needed with no issues. Then tool 1 is picked again.
Tool 1 is primed, makes some moves over the cancelled red objects and then crashes into tool 3, again. It is at this point I realized red, white and green are finished so there is no longer a need to pick these tools. In fact tools 2 and 4 are never picked again.
This cycle repeated itself over and over so I cancelled the print after four or five times of watching in horror. I now wish I would have videoed it happening but it was getting late and I was a bit unnerved by the sound of tools crashing.
I've used the Cancel Objects OctoPrint plugin on the MK3 and have seen the "moves" it makes near a cancelled object but there were never any issues. Of course this implementation is a bit more complex. Not sure if it has something to do with tool 1 being the default extruder or just simply a bug in the code. Maybe both? Definitely at least a bug, pretty sure this is not by design 😐
It basically forgets it has picked tool 1 and goes to get tool 3 it seems.
I plan to submit a firmware bug report in Github once I figure out how to best summarize it.
Has anyone had any similar issues when using the Cancel Object and/or is anyone willing to try to reproduce?
Printing the remaining parts this morning and all is well. No issues and no cancelled objects this time!
Frio,
Did you ever get this resolved. I am running into crashes. Some are recoverable and some not so much. Are you using Prisa Slicer? If so which version? Input Shaping?
RAHRAH
I am the inveterate tinkerer. I can tink up most anything.
RE: Tool crash with objects cancelled - mutli tool, multi-part print
Hi @rah1,
I have not had a crash since the one outlined above (except for one that was my fault). However, I have not used 'Cancel Object' since then either, which I strongly believe was the root cause of those tool crashes. I did submit a bug report on the Prusa-Firmware-Buddy github page but it hasn't seen any action yet.
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3583
- The model was sliced with Prusa Slicer using IS profiles but I'm not sure which version, probably 2.7.0 at that time
- 5.1.0 FW which was the latest at that time.
