Tool changer clamps very loose
Pfrailing
(@pfrailing)
Miembro
So I find that I'm getting alot of tool changer crashes.  Today I was printing a colored benchy, and watched it during a tool change.  It dropped off the first tool fine. But when it went to pick up the next I noticed the clamp bars moved while the head moved, so when it went to pick up they were out of place causing the jam.  Am I missing something, like an adjustment to tighten them a bit?  Not sure what to do.
Respondido : 30/11/2024 4:11 am
michelle653burkes
(@michelle653burkes)
Miembro
RE: Tool changer clamps very loose
Hello!
It sounds frustrating to deal with tool changer crashes, especially during an important print. The issue might be related to the timing or alignment of the clamp bars during the tool change. Ensure that the clamp bars are properly aligned and securely tightened, as misalignment can cause them to move out of place. Sometimes, adjusting the timing of the tool change can help, especially if the head moves too quickly. Additionally, make sure your printer's firmware is up to date, as firmware bugs can cause issues. Perform a calibration of the tool changer to ensure everything is set up correctly, and refer to your printer's manual for specific instructions on adjusting the clamp bars and tool changer settings.
Respondido : 30/11/2024 10:35 am
1 les gusta
Look along the row of docked heads from the side - are they exactly in line?
If a dock is not screwed home by as little as a millimetre it can cause docking and picking problems, even dropped toolheads.
Respondido : 01/12/2024 1:14 am
2 les gusta
hyperion
(@hyperion)
Did you ever solve this problem?  I’m having the same issue, it’s not related to the docks themselves (like some of the replies suggested) but like you the sliding clamps have become so loose that they move around during travel on change and crash face on into the pins.  Is there a way to tighten the sliding clamps?
Posted by: @pfrailing
Respondido : 03/05/2025 7:01 pm
blauzahn
(@blauzahn)
The 2 carrying pins at the cheese board are spring loaded by rubber o-rings. Without this there is backlash. Those o-rings may have become brittle or flattened over time. The pins must be able to move axially.
It is not too difficult to disassemble in order to have a look. When I got my 5-head XL more than a year ago, I had the opposite problem at one toolhead. It was too tight. I found a video on yt showing the disassembly. Unfortunately, I can not find it right now.
Please do not forget to ever so slightly grease the tiny bolt at the carrying pins from time to time.
Respondido : 04/05/2025 9:12 am
