Tool 1 always at 170°C
Jeggo
(@jeggo)
I just starte several single colour jobs on my 5 tool XL. It seems that tool 1 is always on 170°C even if it is not used during the print.
Am I using a corrupted configuration or could someone reproduce this behaviour?
I am using Prusa Slicer 2.7.0 final and firmware 5.1.0 final
I discovered this habit because I configured the status line in the XL display to show all tool temperatures.
Postato : 24/11/2023 3:46 pm
1 persone hanno apprezzato
silvermanphoto
(@silvermanphoto)
RE: Tool 1 always at 170°C
Jeggo, I keep seeing the nozzle "set" to 170C during pre-print ramp up too, but when it starts actually printing it boosts the extruder to the temperature set in the Gcode.
Postato : 26/11/2023 7:17 am
2 persone hanno apprezzato
Jeggo
(@jeggo)
As I was thinking, the problem seems to be located in the Prusa Slicer. There seem to be some remains in some project, that the slicer thinks, that there is an additional tool used. I just sliced a model, that only uses tool 5 and now all other tools are off.
As work around, you can always turn off the tools that are not used in longer prints on the XL.
Postato : 27/11/2023 9:31 am
