Stuck filament detection causing filament to get stuck?
Seite 4 / 5
Anaxagoras
(@anaxagoras)
RE: Stuck filament detection causing filament to get stuck?
I've had my 5T xl for about 2 weeks.  The issue just started happening over night.  Im printing a single color petg part with PLA supports.  The PETG extruder keeps giving a filament stuck error at roughly the same point every time.  The filament is not jammed, if I stop the print and manually extrude filament comes out fine.  I changed the petg from extruder 1 to extruder 2, no difference.  I've done 3 cold pulls.  I realized the file.  I tried a different roll of filament.  The part that makes no sense to me, if this was a firmware but it's been working fine For the last 2 weeks, why start now.  Last thing to try is I'm gonna print other parts to see if it's somehow related to this stl.
Veröffentlicht : 16/02/2025 1:00 am
Anaxagoras
(@anaxagoras)
Update to my previous post.  The print that kept failing repeatedly is an assembly of 8 different single color parts with pla supports.  I was curious if there was an issue with one specific part, since it kept seeming to fail at around 12% and kept failing every time the print head went to part what i will call part "a".  I went into Prusa slicer, and the only change I made was i hid every component, and tried to print one at a time.  I made no other changes in the slicer.  every single one of the 8 parts printed successfully when done 1 at a time!  I then tried to print the whole thing again as just one print, and it again failed at roughly 12%.  Now this isn't a huge print.  All 8 parts printed at 60% infill, with 6 walls and 6 top and bottom layers only uses about 47g of petg (objects +wipe tower), and 88 grams of PLA(supports + wipe tower).
I'm just spitballing and rambling here trying to think some things out in a way that seem logical to me, but i admit i have very little idea of what i'm talking about:
So in my mind I wonder why this is.  I've been considering this all day.  I'm no expert in 3d printing, but i've ruled out a lot of things and i tried to think, how does the stuck filament detection work, it measures back pressure via the load cell in the toolhead.  I'm not 100% sure how this works, i'd love to see a diagram explaining the implemntation, but I know what back pressure is. so what could cause back pressure?
I thought could it be due to part "a" because it kept failing on  part "a" as it was starting to do a 45ish degree overhang, but the part completed successfully on it's own, so no the part itself isn't "unprintable" in some way.  Each individual print time was shorter, so maybe this is related to print time.  Maybe the nozzle starts to get gummed up?  But it seemed very consistent in happening at the same percentage into the print, and i thoroughly cleaned the nozzle when i resumed the print only to have it error when it started printing on "part a".  Maybe the print time is causing some kind of heat creep? but i've printed longer prints with no issue, and the printhead significantly cooled down between the printing pausing and me resuming it by "unloading/loading" filament and it would immediately error out again after getting back to part "a'.
Now maybe it is related a combination of print time and the part geometry?  Maybe printing one at a time each part stayed warmer and didn't have a chance to cool down, and printing multiple parts on the same bed caused the parts to cool down and warp slightly?  Part "a" was a somewhat long rectangular part.  It seems like it kept failing at the same point, so if it was warping it was doing so very consistently.  But if this happened maybe it cause the print head to get a little too close to the part causing more back pressure?
Veröffentlicht : 16/02/2025 8:18 pm
DaJMasta
(@dajmasta)
Running an XL with 6.2.0 firmware and having the same basic issue, mine seems to be specific for faster, short movements, and currently almost exclusively on the 0.25mm layer height speed preset.  Given the circumstances, I think there's something about the way the extruder is handling the filament that makes it think the spool is dragging even when it isn't.  I get several fails without a stuck spool or noticeable damage to the filament per print with 0.25mm layers speed setting, and none with finer heights and slower speeds.  Just had another 0.25mm layer height print stop because of another false positive, and this time on reloading, it immediately failed again - when I pulled the filament to look at the end in the toolhead, the filament had extruder marks but no rubbing present, but I did see a small bowed section that I hadn't noticed in other pulled ends - perhaps plays a role in the fault.  I've only had it happen on one toolhead and only with PETG, but I also print mostly PETG with support PLA on the second, so this could just be because of how frequently it gets used compared to the other.
Diese r Beitrag wurde geändert Vor 1 year von DaJMasta
Veröffentlicht : 16/02/2025 8:42 pm
Noshoes
(@noshoes)
Hi, concerning the stuckt filament issue, in the Menu I disabled the so called "stucked filament detection" (or similar name), in my case that helped.
Veröffentlicht : 17/02/2025 8:22 pm
dabones
(@dabones)
Mitglied
Yes, it helped me too, but the prints are far from ideal. Skipping lines now.
Veröffentlicht : 17/02/2025 9:13 pm
DaJMasta
(@dajmasta)
Yes, disabling the detection does fix it (and has for me), but it still is a useful feature to detect binding or a cross  under in the winding of the filament, so I'd rather leave it on if possible.
Also had an issue where the extruder stopped registering and hard crashed - no chance of recovery - a few times following my stuck filament detection issue.  The Prusa knowledgebase article where it tells you to remove the plastic strain relief on the connector on the toolhead side did work - but it's a bit alarming that the thing designed to fix that problem caused it.  I hope there is a new revision of the printed parts that includes a better locking mechanism so that the strain relief can function properly without partly disconnecting the connector over time.
Veröffentlicht : 21/02/2025 10:44 pm
dabones
(@dabones)
Mitglied
Did not see the Prusa knowledge base article, can u send a link.
I do have the Prusa enclosure and improved parts.
Also had an issue with the filament detection, the test works out, but in while printing it does not, it does not alarm when the spool is empty, just goes on printing air.
For now, I am not printing anymore due to extreme stringing with PETG, waiting for a dryer. Hopefully that helps.
Veröffentlicht : 21/02/2025 11:22 pm
Michal
(@michal-5)
Mitglied
Detected stuck filament occurred for me for the first time today on MK4S, after printing for around half a year with absolutely no issues, running firmware 6.2.2.
I unloaded the filament and loaded it back in according to the instructions but there is nothing stuck, I do hear some weird clicking sound before the error pops up, so I've tried to downgrade the firmware, cold pull, but nothing works.I was able to print the part with detection turned off but I do see some left out parts/strings 2 - 3 cm long, that's probably where the clicking sounds happens.
HOWEVER, what is very interesting, luckily I am printing the part in 7 different colors these are the fillaments that caused the error:Fillamentum RED PLA 2kg rollPrusament Orange PLA 1kg roll
The error did not occur for:Prusament PLA Pink 1kg rollPrusament PLA Blend Royal Blue 1kg roll
I tried increasing the temperature to 225°C, still same issue but occuring LESS!I increased the temperature to 230°C and first issue happened at 70%, which is a huge improvement because before it was heppening like every 1 - 5 minutes.However then I tried 233°C from those 70% that stopped in the previous step and it happened again at 74% and at 76% so since then I turned off the stuck filament detection and I heared the clicking sound (when it would usually pop up the error and stop printing) like 8 times until it finished.
I think there might be a problem with the slicing or something.
Will try some other settings.
Veröffentlicht : 21/03/2025 6:04 pm
XL beta tester for far too long
(@xl-beta-tester-for-far-too-long)
Stuck filament problem SOLVED
Turn it OFF. No failures since.
Veröffentlicht : 27/05/2025 5:23 pm
dabones
(@dabones)
Mitglied
Yes, the error is also gone here, but i do have skipped lines in my print.
Veröffentlicht : 27/05/2025 5:29 pm
IPIND 3D
(@ipind-3d)
I've opened an issue on Github here:
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4724
Give it a like or post your experience in there. Hopefully it gets some attention.
I've referenced this thread.
Veröffentlicht : 21/07/2025 3:40 pm
Kevin Henneman
(@kevin-henneman)
Mitglied
I have same issue, started with xl 2 tool and first print kept getting stuck filament. Turned off the stuck filament sensor and tightened the feed screws 1 turn tighter and used the xl 2 tool for 2 months no other issues. Recently upgraded to 5 tool and the same problems have started all over again , yesterday I turned the stuck filament sensor of and tweaked the 3 new tool heads as I did before and I'm in a 2 day print now, hoping when the spool join feature starts the new tool with a newer tool head I hope this is fixed for now. Running current firmware and black petg on tool 1( existing from original machine) and tool 2 will be a new roll of petg but a new tool head from the upgrade. Hope this is only a firmware issue and someday it will work as designed
Veröffentlicht : 14/08/2025 4:52 pm
bithead007
(@bithead007-2)
I'm likely upgrading to larger PTFE tubes and Festos in an effort to get away from these friction issues.
Veröffentlicht : 25/08/2025 6:31 pm
Jonas
(@jonas-8)
Mitglied
My brand new Prusa XL can't print large flat print without getting stuck filament alarm. I am thinking about turning it off in the Tune meny. But I guess that warpage in the part is the original issue for trickering the alarm . ..
Veröffentlicht : 01/10/2025 4:38 am
jF
 jF
(@jf-2)
What's the latest firmware version that's safe from this?
I started having the issue on my second print after upgrading the firmware last week; I never had that issue before, except that time I tried TPU.
Came this morning and it has stopped like 1h after I went to bed. It was a bit stuck, but I think it was because it cooked in there all night. It got "stuck" again, 15 min later, and that time it was clearly not stuck. It came out on its own, and you could see the shape of the inside of the nozzle, like I did a cold pull.
I disabled the filament stuck detection, and now it's working fine.
Veröffentlicht : 19/11/2025 4:18 pm
Kevin Henneman
(@kevin-henneman)
Mitglied
I did the same thing, turned off sensor and did some tweaking to the tension screws on top of the nextruder , I loosened both about 3 turns maybe 4,  and I feed my tpu now from a pipe that I hung from the ceiling so there is no drag from the tpu going through the ptfe tubes.  It's worked good for me so far
Veröffentlicht : 19/11/2025 5:30 pm
Kevin Henneman
(@kevin-henneman)
Mitglied
Also I'm running the current firmware for the XL 5 tool,  latest update I think was in October of 2025
Veröffentlicht : 19/11/2025 5:31 pm
Robert
(@robert)
Not sure this was ever just a fw issue. I was testing it quite extensively some time ago, changed recommended firmwares couple of times there and back, unfortunately no proper success. It never really worked for me e.g. if the filament was stucked printing did not stop multiple times, on the other hand it stopped printing unexpectedly when there was no stuck at all.
At least on my side this functionality is switched off forever in printer menu.
Veröffentlicht : 20/11/2025 12:29 pm
Michal
(@michal-5)
Mitglied
Actually I went throught everything with support and the only solution was to decrease to 0,25mm layer height and not use 0,28mm
Maybe it is material's fault, I don't know, 1st time I noticed the issue was with red PLA 2kg from fillamentum and only on a specific part
Some materials and different parts have no problem printing with 0,28mm
Nevertheless I switched completely to 0,25mm layer height and less and everything works 100% since then
Veröffentlicht : 20/11/2025 9:18 pm
Phil
 Phil
(@phil-10)
I'm so pleased to see this thread
So first, apologies cos I'm usong a MK4S, but I'm sure its relevant.
Upgraded from a MK3s+ to the MK4S in mid 2025 and it worked like a dream. Great prints, and reliable...
Like a good boy I upgraded the firmware to 6.4.0 when it arrived and now I get a 'stuck filament error' after a print. Thus I do a print and its fine, next time though it claims stuck filament. So I do an unload and then load filament and it prints fine and the next print it fails and I unload and reload.
FWIW I tried a cold pull, which was successful (in as much as the printer didn't explode) but it didn't clear the problem.
I'm very much a newbie to 3D printing, but I've been dealing with failing FW upgrades for 40 odd years, and this looks very much like a firmware problem.
I post to say thank you for helping me to get my head around the problem, and to suggest this is (mostly) a firmware problem
Cheers
C
Veröffentlicht : 02/01/2026 2:12 pm
Seite 4 / 5
