Printer Beeping but no Errors - Bed Temp Issue?
Extra Fox
(@extra-fox)
I had a 3 hour print running today on my XL. Apart from the usual, lousy "perfect first layer", the print was going okay.
Then towards the end of the print, the printer started beeping randomly. There only thing I can tell on the screen is that that the values for the bed temperature are flashing red and  it was about 5 degrees cooler than the target. So here's the questions.
  1. Is this the cause of the beeping?
  2. Prusa's firmware is managing the bed temps so why can't the printer maintain bed temperature?
I'm printing in a heated, interior room. The room is right around 21C, so normal room temperature. Humidity is normal (~38%) and there are no drafts.
Aaron
Opublikowany : 18/01/2025 7:14 pm
