[Résolu] PETG support stuck on satin sheet
Tellblom
(@tellblom)
Membre
I think I have tried everything to get it of, freezer, hot bed, IPA but it is stuck.
How do I get it of and why did it happens? Esun Petg,have printed a lot with it before without any problem, and big support area.
How do I  gwt this of ?
Why does it stuck like its welded?
How do I avoid this on my new sheet (yes part of the satin sheet was stuck on the part also so it's ruined).
Best Answer by Tellblom:
Ok got it off setting bed temp to 95 and peeled it off.
I also know what happened. It printed using ABS settings so headbed 110 and nozzle 250.
Do not use that on PETG on a satin sheet, it will be destroyed.
Publié : 25/02/2025 6:53 am
Tellblom
(@tellblom)
Membre
RE: PETG support stuck on satin sheet
Publié : 25/02/2025 10:48 am
Didn't the printer warn you about incompatible filament loaded for your chosen filament settings? Make sure it's turned on in your printer's menu. Has saved my bacon many times
Publié : 25/02/2025 12:43 pm
Tellblom
(@tellblom)
Membre
No it didn't. It was my own filament setting for a Voron printer so it wasn't correct proberbly
Publié : 25/02/2025 12:54 pm
