PETG support stuck on satin sheet
I think I have tried everything to get it of, freezer, hot bed, IPA but it is stuck.
How do I get it of and why did it happens? Esun Petg,have printed a lot with it before without any problem, and big support area.
How do I gwt this of ?
Why does it stuck like its welded?
How do I avoid this on my new sheet (yes part of the satin sheet was stuck on the part also so it's ruined).
Best Answer by Tellblom:
Ok got it off setting bed temp to 95 and peeled it off.
I also know what happened. It printed using ABS settings so headbed 110 and nozzle 250.
Do not use that on PETG on a satin sheet, it will be destroyed.
RE: PETG support stuck on satin sheet
Didn't the printer warn you about incompatible filament loaded for your chosen filament settings? Make sure it's turned on in your printer's menu. Has saved my bacon many times
No it didn't. It was my own filament setting for a Voron printer so it wasn't correct proberbly
