Official enclosure: Filtration settings per filament?
NoeG
 NoeG
(@noeg)
I'm having trouble understanding what controls the filtration (or not) on the printer.
From the official page ( https://www.prusa3d.com/product/original-prusa-xl-enclosure-2/#parameters):
The XL printer automatically controls the filtration and utilizes airflow where the air is drawn in from below and blown through the HEPA filter out of the Enclosure.
For materials that do not produce as many particles and odors (such as PLA and PETG), filtration is not used to extend the life of the HEPA filter, but can be activated manually.
However, on the printer, I can only see "manual settings", with toggle buttons, speed, etc.
I can't find any settings on the prusaslicer either.
Is the filtration on/off built-in in the printer as a function of the filaments being used (at the moment, or, at any point during the print)?
I have the impression that the filtration used to run all the time, when using PLA / PETG.
Do the "manual settings" reset after each print? Is there a way to reset the manual overrides to "auto"?
Postato : 23/09/2024 6:22 pm
Brian
(@brian-12)
The only things you can control at the moment are fan speed and how long the Filtration runs after completing a print.
Personally for me this has been great because I used to control the filtration system with a smart plug.  That worked but I had to manually set a timer every print.  Now it's all automatic.
Also I'd use the Filtration for every print.  No matter what filament your using it's expelling micro particles into the air, so keeping the enclosure closed and running the filter is always a good idea.  With the chamber being passively heated I've never had an issue leaving the doors closed, even on 20 hour PLA prints.
Here's an interesting video on air quality around 3d printers.
Postato : 26/09/2024 3:36 am
