nextruder make clicking sound
Página 1 / 2
wessje1
(@wessje1)
I have a problem with the Nextruder on my Prusa XL dual toolhead.
The printer starts printing, but then the extruder gear begins making a clicking sound. Sometimes the clicking lasts only a short time and the printer stops extruding filament, after which it starts printing again. Other times, it stops extruding completely.
The nozzle is not clogged, and there is no debris inside the Nextruder. The extruder motor keeps turning, so I’m not sure what the issue is. I also checked whether the nozzle was overtightened, but this did not solve the problem.
Respondido : 05/02/2026 9:44 am
jan.d.slay
(@jan-d-slay)
RE: nextruder make clicking sound
Did you load a filament into the Nextruder whose temperature was higher than the filament currently loaded?
Have you tried inserting a filament and setting the temperature higher than specified (270–280 degrees) and flushing very often?
Have you checked/adjusted the preload of the two screws on the idler?
Is the filament running straight into the nozzle at the top?
Is the roller from which the Nextruder unrolls free to move?
Respondido : 05/02/2026 9:56 am
wessje1
(@wessje1)
I am using a new Prusa nozzle.
I tried flushing the nozzle, but it did not resolve the issue.
I checked the two idler screws.
The filament path is straight,
and the filament roll moves freely.
If i unload the filament and spin the nextruder gear with my finger it gets stuck somtimes.
Respondido : 05/02/2026 10:03 am
jan.d.slay
(@jan-d-slay)
That's a very good point.
Is the original lubricant still in there?
If so, I would remove the gears and clean everything.
Respondido : 05/02/2026 10:12 am
wessje1
(@wessje1)
I cleaned the gears two days ago and used the aligner to reinstall them, but the problem is still occurring.
Respondido : 05/02/2026 10:22 am
jan.d.slay
(@jan-d-slay)
Posted by: @wessje1
Can you start printing and observe the noise/behavior? Or does it occur randomly/sporadically?
When does this occur most frequently?
Which filaments are most prone to this?
What nozzle diameter do you use, and what is your nozzle temperature and layer height?
What is the maximum volumetric speed?
Respondido : 05/02/2026 10:29 am
wessje1
(@wessje1)
I always print with PLA on that extruder.
The nozzle diameter is 0.4 mm, the temperature is 230 °C, and the layer height is 0.2 mm.
It usually happens after the printer has completed around 20–40 layers.
I started a print today, and when it happened, I heard a clicking noise. I touched the extruder and could feel vibrations while it was clicking. During that time, no filament was extruded, and when the clicking stopped, it started extruding filament again.
The maximum volumetric speed is set to 0 mm³/s.
Respondido : 05/02/2026 10:43 am
jan.d.slay
(@jan-d-slay)
I think we're slowly getting to the root of the problem.
To me, your description points to insufficient cooling from the heat sink.
I don't know where your printer is located or how “warm” it gets, but I suspect that the PLA filament is becoming too soft, preventing the extruder from feeding it.
You either need to lower the room temperature or increase the speed of the heat sink fan.
I had to do the latter once in an emergency when my temperature sensor on the XL was defective. I soldered four 10kOhm resistors in series so that the fan ran at maximum speed. (I was printing PCCF at the time and had to help myself somehow)
This means that if you want to start another test print, you will certainly find a softer and compressed piece of filament behind the idler when, after a certain amount of time, the heat from the heatsink has slowly softened the PLA.
Respondido : 05/02/2026 10:55 am
wessje1
(@wessje1)
Thanks, I will try increasing the speed of the heatsink fan.
The room temperature is 20–22 °C.
Respondido : 05/02/2026 11:00 am
1 les gusta
jan.d.slay
(@jan-d-slay)
As I said, it's just a guess from a distance.
You can display the fan speed and the temperature of the heat sink on the display.
Respondido : 05/02/2026 11:21 am
wessje1
(@wessje1)
I’ve tried it, but it doesn’t seem to work.
Respondido : 09/02/2026 8:30 am
jan.d.slay
(@jan-d-slay)
Can you please describe in more detail what you tried to do?
Respondido : 09/02/2026 8:41 am
wessje1
(@wessje1)
I increased the fan speed to improve filament cooling, but it doesn’t seem to have any effect.
Respondido : 09/02/2026 8:54 am
jan.d.slay
(@jan-d-slay)
Posted by: @wessje1
Oh, I think we're talking at cross-purposes.
The fan speed for the filament fan and the fan speed for the heat sink fan are two separate things.
The speed for the filament can be easily adjusted. The speed for the heat sink is a control circuit that cannot be controlled externally!
I already wrote about “tricking” the temperature sensor so that it spins faster. To get more speed for the fan that cools the filament in the heat sink, you have to trick it into thinking that the heat sink is 50 or 60 degrees. You can only do this if you have a fixed resistance where the software can read a higher temperature.
I can't say for sure whether this is a solution to your problem from a distance. The fact is that it is one possibility.
Please read the heat sink temperature on the display during printing. I would like to know what temperature it shows when the noise occurs. It may also be that the sensor is “defective” and is providing incorrect values.
Respondido : 09/02/2026 10:01 am
Pe3d
 Pe3d
(@pe3d)
Is this occuring on both printheads?
Do you have an enclosure?
Maybe its the Sensor and the Temperatur is unstable?
How fast are you Printing?
Filament feeding runs smooth?
3mf?
Respondido : 09/02/2026 1:04 pm
wessje1
(@wessje1)
The issue occurs only on tool 1.
I am using the standard Prusa settings, which worked correctly for a long time. Recently, this problem started occurring.
The filament extrudes normally at the start of the print, but partway through the print it stops extruding.
I am not using an enclosure.
The print head temperature remains stable and has been verified.
No 3MF file.
Posted by: @pe3d
3mf?
Respondido : 09/02/2026 1:27 pm
jan.d.slay
(@jan-d-slay)
I think the next step would be to find out what temperature the sensor measures.
Respondido : 09/02/2026 1:50 pm
Pe3d
 Pe3d
(@pe3d)
To Show Heatbreak Temperatur
On your printer:
Settings/User Interface/Footer
There you can Show 5 different values during Print.
Try a cold pull
Try to tighten the idler
Try setting your mvs to 12-18 max. (my petg settings)
If you Take a Look at your sliced Print at the Speed. Is there Something Like faster layers?
Respondido : 09/02/2026 3:55 pm
Pe3d
 Pe3d
(@pe3d)
Have you updated your Firmware recently?
Respondido : 09/02/2026 3:59 pm
wessje1
(@wessje1)
Yes, but I had the same issue before.
Posted by: @pe3d
Respondido : 09/02/2026 4:03 pm
Página 1 / 2
