Nextruder Adjusting Tension Hard?
Tad
 Tad
(@tad)
Folks, am I crazy? I was trying to loosen the pressure on the extruder gear as suggested by the article to print TPU, but the shroud completely blocks access to the adjustment screws. I searched, but I have to assume either Prusa or a modder has fixed this problem somehow? Or what am I missing? For background, I have a pretty early 5-tool machine (yes the one that came with the 0.6 nozzles).
Thank you in advance for any advice.
Best,
Tad.
Best Answer by BaconFase:
There are several dwarf board cover remixes on Printables to help with getting at the tensioning screws heads on the XL.
Here are a couple
https://www.printables.com/model/732561-prusa-xl-dwarf-cover-door-with-a-channel-for-an-al
https://www.printables.com/model/734232-original-prusa-xl-skeletton-dwarf-board-door
Posted : 21/06/2025 3:09 pm
RE: Nextruder Adjusting Tension Hard?
What article?
I should preface it by saying that I haven't printed much TPU on my XL (also one of the first models) and didn't have any issues. Assuming you're referring to the idler screws I don't see how the shroud would block access.
Here's the Prusa KB article on adjusting idler strength for TPU: https://help.prusa3d.com/article/idler-screw-tension_177367
Posted : 21/06/2025 11:03 pm
BaconFase
(@baconfase)
Here are a couple
Posted : 22/06/2025 5:52 am
