Loading low temp filament
patternman
(@patternman)
I always unload my filament when done printing to prevent filament from getting wet and breaking in the PTFE.
When loading a low-temp filament into extruder that had a high temp filament say from PC to ABS The PLA cant push thru.
I load the PLA as ABS then unload and reload as PLA. Is there a way to load without going thru this cycle?
Napsal : 22/12/2025 10:14 pm
The general advice is always to load at the higher temperature and purge out any filament residue.
A method which I repeatedly resolve to adopt but inevitably forget is:
When unloading high temperature filament always reload PLA scrap at the high temperature then unload again.  In theory it always leaves the printer in a ready-for-any-filament condition - it works - if only I remembered to do it every time.
Napsal : 23/12/2025 12:38 pm
patternman
(@patternman)
RE: Loading low temp filament
You're saying load the p l a at a higher temp , Such as loading it as ABS. Is there any way in the software to tell it It's actually pla without going through unloading it and reloading it again as pla?
Napsal : 24/12/2025 7:36 pm
