Layer Shift when using Spool Join on XL-5T
I have seen a few posts talking about the Spool Join creating artifacts or getting the wrong Z-Height.
In my case, it has produces a very prnounced X-Y layer shift:
It has worked fine in the past, this is the first time I have noticed. This is a multi-part print and all the parts showed identical layer shift. All heads where calibrated when the printer was setup and nothing has changed since then (at least intentionally).
Any ideas besides "Try running the X-Y calibration again?".
Thanks.
Publié : 21/04/2026 12:00 pm
RE: Layer Shift when using Spool Join on XL-5T
Check if tools back plate have play when you remuwe the tools and recalibrate them shoud help.
Publié : 24/04/2026 10:19 am
